Topic: retrieve a data on csv file using sd card module and arduino uno (Read 572 times) previous topic - next topic
francisagrava
hello guys im working on my embedded thesis and my only problem is the retrieving data on csv file from sd card module. the scenario is like this when i insert a coin thermal printer will give you a unique username and password. the unique password is stored on sd card module please help me :D
Code: [Select]
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
volatile byte CoinPulseCount = 0;   // a counter to see how many times the pin has changed - which coin inserted
volatile byte hopperPulseCount = 0;  // a counter to she how many coins have been ejected
volatile unsigned long PulseTime;  //this stores the time of the last pulse.
byte NewCoinInserted;
byte Command = 0;
byte pulseThreshold = 200;  //EDIT THIS VALUE TO CHANGE DELAY BETWEEN DETECTING BANK OF PULSES
int hopperPin = 2;  // pin2 as optical count input
int coinSelectorPin = 3;  // pin3 as optical count input
int relayPin = 7;  // pin7 output relay
String OnePulse = "5 peso inserted";
String TwoPulses = "5 peso inserted";
String ThreePulses = "10 peso inserted";
SoftwareSerial mySerial(RX_PIN, TX_PIN); // Declare SoftwareSerial obj first
Adafruit_Thermal printer(&mySerial);
  mySerial.begin(19200);
  pinMode(hopperPin, INPUT_PULLUP);
  pinMode(coinSelectorPin, INPUT_PULLUP);
  pinMode (relayPin, OUTPUT);
  digitalWrite(relayPin, HIGH);
  digitalWrite(hopperPin, HIGH);
  attachInterrupt(1, coinacceptor, FALLING);
  lcd.begin (16, 2); // for 16 x 2 LCD module
  lcd.print("Coinect Hotspot");
  printer.begin();
  //CHECK NOW TO SEE WHICH COIN IS INSERTED
if(CoinPulseCount > 0 && millis() - PulseTime > 200){
                NewCoinInserted = CoinPulseCount;
                CoinPulseCount = 0;
  //Proccess the coin inserted
  switch (NewCoinInserted)
                case 1:
                        lcd.setCursor(0,1);
                        lcd.print(OnePulse);
                        NewCoinInserted = 0;
                case 2:
                        lcd.setCursor(0,1);
                        lcd.print(TwoPulses);
                case 3:
                        lcd.setCursor(0,1);
                        lcd.print(ThreePulses);
//*****INTERUPT detecting pulses from the coin acceptor
void coinacceptor()      //Function called when coin enters coin acceptor
  CoinPulseCount++;
  PulseTime = millis();   //store current time in pulseTime
PaulS
Quote
Under what circumstances do you want to read data from the file?
Which record do you want to read data from?
What do you want to do with that data?
francisagrava
Sorry for my late reply. my embedded thesis is a wifi vendo machine. i want to retrieve the unique username and password from sd card module save as csv file from MikroTik the username and password is auto generated by MikroTik router and i will only save it to sd card to print it when the coin acceptor detect the coin inserted and show on the lcd screen all the transaction happening
