aMTP32M - help with bit clock
i'm trying to get control an Aplus chip aMTP32M (stores audio samples) with UNO having never gone down on binary before. I have tried a few things with SPI, know about MOSI and SCK and read much in the forums and tried to apply what I recently picked up from a my mini-project with shift registers. However, i'm might be looking at it so much that i missed the simple answer [alt. m just a dunce.] The pic aptly describes my question. Any input to ease my death is appreciated...
What's the question? Post your code and describe what is or isn't happening.
Yes, sure. This chip (I believe assigned through software) requires just 2 lines, data and clock. I need to produce this sequence of signals from Arduino to trigger the playback of particular tracks. Sending just 00000000, 00000001, etc. to trigger track 1, track 2, respectively. The chip will play, but not based on the commands I send it. So, my question is what is the proper way to send serial based on the model I provided in the image?
I am interested in just having a simple test code run cleanly.
int clockPin = 13;
int dataPin = 11;
int i = 0;
byte b = B00000000;
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
digitalWrite(clockPin, LOW);
if(i==0){
  b = B00000000;
if(i==1){
  b = B00000001;
if(i==2){
  b = B00000010;
shiftOut(dataPin, clockPin, MSBFIRST, (b, BIN));
Serial.println(b, BIN);
 delay(10000);
i++;
  if(i>=2){
    i=0;
You've lost me a bit with the Serial.println.
And this:
if(i==2){
  b = B00000010;
Binary is just another way of looking at a number. You may as well have written:
if(i==2){
  b = 2;
You can see that doesn't achieve much, right?
You are confusing a number of things here. I suggest you read this for a start:
Then post a link to this device. If you are still confused we can talk then. Hint: you don't want to do Serial.println. You are swapping from SPI to async serial. They are different things.
Nick, thanks for the link, it DID clarify protocols. I have included code to I am running based on what I figured from the readings. My intent is to use the SPI library. From some examples, it appears the library takes care of the pin assignments. After playing around with the settings, I found one mode which changed the track, but it was more like a toggle between two tracks, not a sequence. So, if I am using the SPI functions correctly, I'm thinking the problem is either with the chip, which can be set for 4 different types of communication, or I am using the wrong serial protocol. I'm not able to find more documentation then states serial, but the diagram seems to illustrate a synchronous protocol, minus a latch. Let me know what you think, if you think the code checks out, I will make a trip back to the local Aplus distributor to double check how it was programmed.
#include <SPI.h>
//int clockPin = 13; //SCK
//int dataPin = 11; //MOSI
int ss = 10; //slave select
  //pinMode(clockPin, OUTPUT);
  //pinMode(dataPin, OUTPUT);
  //pinMode(ss, OUTPUT);
digitalWrite(ss,LOW);
  //SPI.setBitOrder(MSBFIRST);
  //SPI.setClockDivider(SPI_CLOCK_DIV4); //default value = 4
  SPI.setDataMode(SPI_MODE3);
  mode 0 >> CPOL = 0 & CPHA = 0 (plays song #1 loop)
  mode 1 >> CPOL = 0 & CPHA = 1 (plays song #1 loop)
  mode 2 >> CPOL = 1 & CPHA = 0 (plays song #2 loop)
  mode 3 >> CPOL = 1 & CPHA = 1 (alternates between #2 and #3)
  SPI.begin();
  for(int i=0; i<=5; i++){
    delay(2000);
    SPI.transfer(i);
    delay(2000);
The code looks OK, as far as it goes. Can you post a link to the chip datasheet?
Here is the link to the product page:
http://www.aplusinc.com.tw/pro-multi2.html
And, here is the link to the datasheet PDF:
http://www.aplusinc.com.tw/pro-download/aMTPxxM-Datasheet_V1.0_20111223.pdf
I found the serial info to be a little vague, but maybe you can make sense of it. Perhaps this doesn't need a clock at all.(?)
How have you got it wired?
Sorry for the hold, but I wanted to check back with the distributor. The chip is mounted on PCB, with circuits for a basic amp, for it is normally designed to be placed in a prayer box.
So, I goofed, misunderstanding his accent and my funky Hindi comprehension skills. He programmed it for Key Trigger mode, not Serial. This requires a little more soldering. The pins on the chip PD1,PD2,PB0,etc. [as mapped out in the chip documentation] can be connected directly with Digi Outs of the Arduino. Of course, this code looks different and has a 30 track limit. i'm including sample code which uses a Digi In from the chip's BUSY signal pin to cue generation of a random track number. Please let me know if my coding can be better. m always wanting to improve.
Anyway, now that that worked, I will have the chip re-programmed and try out the SPI code in a few days.
const int track[] = {
  8, 9, 10, 11, 12, 13 };//PB0,PB1,PB2,PB3,PD1,PD2
int trackCount = 8;//number of samples
int busy = 7;//PD0 out
int val = LOW;
  for (int Pin = 0; Pin < trackCount; Pin++){
    pinMode(track[Pin], OUTPUT);
  pinMode(busy, INPUT);
  randomSeed(analogRead(0));
  val = digitalRead(busy);
  if(val==LOW){
    int randNumber = random(trackCount);
      if(randNumber<=5){
        digitalWrite(track[randNumber], HIGH);
        delay(50);
        digitalWrite(track[randNumber], LOW);
        //Serial.print("single ");
        //Serial.println(track[randNumber]);
        //Serial.print("rand ");
        //Serial.println(randNumber);
      if(randNumber>5){
        digitalWrite(track[(randNumber - 6)], HIGH);
        digitalWrite(track[(randNumber - 5)], HIGH);
        delay(50);
        digitalWrite(track[(randNumber - 6)], LOW);
        digitalWrite(track[(randNumber - 5)], LOW);
        //Serial.print("double ");
        //Serial.print(track[(randNumber - 6)]);
        //Serial.println(track[(randNumber - 5)]);
      delay(100);
 if(randNumber<=5){
 if(randNumber>5){
You could put in an "else". If the number is not <= 5 it must be > 5 right?
 if(randNumber<=5){
 else {
Ok, and in following the same logic, the else if statements could continue to handle the 30 track max. for a chip programmed in key trigger mode. The chip was re-programmed to accept CPU serial mode, but the code using the SPI library from before is not triggering playback. I've tried modes besides what seems like the apparent one SPI.setDataMode(SPI_MODE3); but still no response. I also tried slowing down the clock divider but to no avail. I'm a little stumped; the image in from the datasheet represents a synchronous transfer minus a latch, right?
What to do?
#include <SPI.h>
int clockPin = 13; SCK  = PB0 out
int dataPin = 11; MOSI = PB1 out
int busy = 7; //PD0 busy signal
  SPI.setClockDivider(SPI_CLOCK_DIV8); //default value = 4
  SPI.begin();
    SPI.transfer(i);
    delay(5000);
Could you draw your exact wiring and/or produce a photo?
I included a photo in an earlier post, but I think it is impossible to follow. A simple layout follows. of course, it does not have the schematic for the board the aMTP32M is mounted on, but I am going pin-to-pin.
No ground wire?
Yes, the ground is shared with the other components on the board. So Arduino is providing the 5v and gnd.
DeFenestrated:
When I said "exact wiring" I had in mind that you would show the exact wiring.
Not omitting ground, +5V, reset pin and so on. One of the pins that you don't think is important might in fact be the clue to the whole thing.
