Topic: converting from ethernet to (node mcu) WiFi (Read 949 times) previous topic - next topic
Thersonder
Basically I want to convert the Settimino (arduino Snap7 library) across to WiFi using the nodeMCU as an arduino. I have edited the Settimino library to #include ESP8266WiFi  and changed the class from ethernet to WiFi, however I get compiler errors from Arduino IDE that I dont quite know how to fix.
Has anyone else had experience with porting an ethernet based library to wifi or how to fix these errors.
Thank you.
Code: [Select]
In file included from C:\Users\Geoff-Work\Documents\Arduino\libraries\Settimino\Settimino.h:42:0,
                 from C:\Users\Geoff-Work\Documents\Arduino\libraries\Settimino\Settimino.cpp:26:
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [22]; size_t = unsigned int]':
\Documents\Arduino\libraries\Settimino\Settimino.cpp:426:41:   required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [22]'
     size_t left = source.available();
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [22]'
     source.read(buffer.get(), will_send);
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [25]; size_t = unsigned int]':
\Documents\Arduino\libraries\Settimino\Settimino.cpp:446:39:   required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [25]'
C:\Users\Geoff-Work\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [25]'
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = unsigned char [35]; size_t = unsigned int]':
\Arduino\libraries\Settimino\Settimino.cpp:543:34:   required from here
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'unsigned char [35]'
\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'unsigned char [35]'
exit status 1
Error compiling.
Norbert21059
I have the same problem.
Can anyone help?
jnogues
Hi Norbert and Thersonder. Could you do it yet? I'm working with ethernet shield with no problem but I need a wifi connection, Do you try another wifi board?
Regards
dgi52
Hi Thersonder,
Have you done it? If not, I think you should contact to owner of the library directly and make a request for porting the lib to another platform.
http://settimino.sourceforge.net/
Java Programming Forums -> http://www.java-forums.org
jnogues
Hi, I post a topic in snap7 discusion forum but nobody answer the question.
I dont have skills for port it, but I thing than adding wifi inputs and outputs to
0BA7  and 0BA8 Siemens Logo! Is very interesting. Well, I hope somebody
With more programming experience are interested.
Regards
