Ciao,
ho fatto questo misuratore di temperatura con questo sensore LM335Z e ho collegato con Arduino Uno R3 con Arduino GSM Shield che invia dati a Cosm
https://cosm.com/feeds/8526 vedi sensor_reading.Ma il codice della temperatura del sensore mi da errati dati.Che cosa devo fare?Grazie.
* Cosm Arduino sensor GSM client example.
* This sketch demonstrates connecting an Arduino to Cosm (https://cosm.com),
* using the new Arduino library to send and receive data and the new GSM library.
* Requirements
* * Arduino with (Telefonica-designed) GSM shield
* * Arduino software with version >= 1.0
* * An account at Cosm (https://cosm.com)
* * A temperature sensor connected to pin 3
* Adapted 1 April 2013 by Dan Appelquist from a sample program
* created 8th January, 2013 using code written by Adrian McEwen with
* modifications by Sam Mulube
* Full cosm tutorial available here: https://cosm.com/docs/quickstart/arduino.html
* This code is in the public domain.
#include <Cosm.h>
#include <HttpClient.h>
#include <GSM.h>
#define API_KEY "XXXX" // your Cosm API key
#define FEED_ID XXXX // your Cosm feed ID
// PIN Number
#define PINNUMBER "" // your sim PIN number if you have one (most don't)
// APN data
#define GPRS_APN "bluevia.movistar.es" // replace your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
// initialize the library instance:
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// Analog pin which we're monitoring (0 and 1 are used by the Ethernet shield)
int sensorPin = A3;
unsigned long lastConnectionTime = 0; // last time we connected to Cosm
const unsigned long connectionInterval = 500; // delay between connecting to Cosm in milliseconds
// Initialize the Cosm library
// Define the string for our datastream ID
char sensorId[] = "sensor_reading";
CosmDatastream datastreams[] = {
CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),
// Wrap the datastream into a feed
CosmFeed feed(FEED_ID, datastreams, 1 /* number of datastreams */);
CosmClient cosmclient(client);
Serial.println("GSM Cosm Sensor Client Example");
Serial.println("==============================");
// main program loop
if (millis() - lastConnectionTime > connectionInterval) {
// read a value from the pin
int sensorValue = analogRead(A3);
float voltage = sensorValue * (3.3 / 1023.0);
float temperature = (3.24 - .48828125) * 100;
// initialize GPRS connection
Serial.println("Initializing network");
// connection state
boolean notConnected = true;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while(notConnected)
if((gsmAccess.begin(PINNUMBER)==GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY))
notConnected = false;
Serial.println("Not connected");
Serial.println("Network initialized");
Serial.println();
// send it to Cosm
sendData(temperature);
// disconnect the GPRS connection
Serial.println("Network disconnected");
client.stop();
// update connection time so we wait before connecting again
lastConnectionTime = millis();
// send the supplied value to Cosm, printing some debug information as we go
void sendData(float sensorValue) {
datastreams[0].setFloat(sensorValue);
Serial.print("Read sensor value ");
Serial.println(datastreams[0].getFloat());
Serial.println("Uploading to Cosm");
int ret = cosmclient.put(feed, API_KEY);
Serial.print("PUT return code: ");
Serial.println(ret);
Serial.println();
// get the value of the datastream from Cosm, printing out the value we received
// not used for this sample but useful if you want to get data back from cosm
void getData() {
Serial.println("Reading data from Cosm");
float ret = cosmclient.get(feed, API_KEY);
Serial.print("GET return code: ");
if (ret > 0) {
Serial.print("Datastream is: ");
Serial.println(feed[0]);
Serial.print("Sensor value is: ");
Serial.println(feed[0].getFloat());
Serial.println();
