I'm trying to get the Illuminato Genesis to work with the 1.0 release.
So far, I have it loading stuff onto the board and I can change whether the built-in LED is lit... but only by setting it as an output pin. I can not turn it off in the main loop. If I do not configure it as output, it stays dim.
Does anyone have any suggestions for how to proceed? I haven't managed to work out the new timer syntax (the numbers changed, should I use the new #DEFINEd names for them, or use the constant names and trust that the new values are right for the chip?) Also... how do I configure the Soft PWM stuff?
Do I need to work out how to get I2C working from the device?
That would be fantastic. If you could simply tell me the correct set of keywords to use, I would be over the moon.
However, I have not yet found a good guide to the data structures in pins_android.h. I took a stab at them and I think I have everything but the timers fixed up correctly. But as described in the first post, I have managed to light the on-board LED, but can only get it to light with the statement pinMode(13, OUTPUT). When I do digitalWrite(13, LOW) from the setup() or main()... it does not go low. However, if I do a pinMode(13, OUTPUT); pinMode(13, INPUT); The LED does not illuminate.
So... I am getting code to run on the platform, and I have enough of the structures set up correctly for the board so that it has the right pin 13. But at that point I am stumped.
If there is a good guide to porting the android internals to a "new" platform, I have not yet found it.
Since you clearly think it is obvious, I am eager to hear your suggestions!
Where did I say anything like that?
You come barging in here asking questions about something I've never heard of, and saying that you are having trouble porting it to the Arduino. I asked you for a link, and you replied with a bunch of code that makes no sense.
I don't think we are on the same page, here. In fact, I'm not sure we're even reading from the same book.
knobunc:
The Illuminato was the first Arduino I bought. The support files for the IDE were never created. 2 (3?) years later, it still takes up space in my parts box.
