Ok, Found it.
Typo, that I made in the Libs SdFile.cpp for root.ls() ,
I pasted an #endif inserted on same line as w++,
so it was ignored - yielding endless loop.
I added this, to fix the ArduinoZero/NanoArm print() to feed back to UsbProgrammer as SerialPort :
#ifdef SERIALUSB_E
SerialUSB.print(...);
#else
Serial.print(...);
#endif
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT16
Volume size (bytes): 3960733696
Volume size (Kbytes): 3867904
Volume size (Mbytes): 3777
Open Root:
Files found on the card (name, date and size in bytes):
SDCARD4G.TXT 2017--19 18:38:46 10
FILE01.TXT 2017--19 18:38:50 0
FILE02.TXT 2017--19 18:39:00 0
FILE03.TXT 2017--20 00:11:54 0
DIR01/ 2017--20 00:12:06
- done!
- don't understand why the PrintDir() func doesn't work though ... :
void printDirectory(File dir, int numTabs)
while (true)
SerialUSB.println(".");
File entry = dir.openNextFile();
if (! entry)
// no more files
break;
for (uint8_t i = 0; i < numTabs; i++)
SerialUSB.print('\t');
SerialUSB.print(entry.name());
if (entry.isDirectory())
SerialUSB.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
SerialUSB.print("\t\t");
SerialUSB.println(entry.size(), DEC);
entry.close();
SerialUSB.println("--");
