Topic: 3 PWM for 3 phase inventer (Read 33473 times) previous topic - next topic
antz975
Perhaps I am  wrong,. The only thing I am unsure of is how how it he IGBT driver know to switch the negative and not the positive?  Every schematic I've seen shows a two inputs per phase. One high side and one low side.
michinyon
You need to carefully read through the datasheets for devices such as
http://www.irf.com/product-info/datasheets/data/irs2330pbf.pdf
http://www.ti.com/product/drv8313
http://www.intersil.com/content/dam/Intersil/documents/an96/an9642.pdf
http://cache.freescale.com/files/analog/doc/fact_sheet/MC33395FS.pdf
And when you understand what all of these gadgets do,    you will have a better understanding of the process which you want to achieve,  and how to drive them.
adelo14
thx  michinyon
i have a idea about this drivers
baso_syahrul
hi,
my project is using arduino to generate 3 phase. and i use ir21362 as my driver 3-phase brigde. i can't figure out it. anybody can help me.. best regards.
MarkT
3-phase what though?  sinusoidal, trapezoidal?  With controllable amplitude? Frequency?
Have you tried generating a single phase in the first case?
baso_syahrul
sinusoidal with controllable frequency. i
adelo14
hello ,  i'm back to complete my projet i have stop in control frenquence so no idea about it ?
MarkT
So what code do you have now?  (Or if you've posted it before please confirm which
reply # its in)
adelo14
reply # its in)
# its in
polymorph
And there is the problem with text-speak.
MarkT is asking you to provide which number (# is shorthand for "number", sometimes) message your current code is posted in, if you have already posted it. If not, please post your current code.
Like this. Is this the current code, or have you made changes since this was posted?
Message # 1719907
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
babina
adelo14 : what did you do ?  i m in the same problem now , i want to control 6 IGBT  , DDS is solution ? what its + and - caracteristics ? please help me
said_ragab
#86
Jan 11, 2018, 11:07 pm Last Edit: Jan 11, 2018, 11:13 pm by said_ragab
to control of 3 phase induction motor , please help me, any one
MarkT
ard_newbie
The Arduino DUE PWM peripheral has a Synchro feature. You can generate 3 sine waves, with the exact same frequency phase-shifted 120 degrees with respect to each other. The sine wave is realized by varying the duty cycle automatically by a DMA. In loop(), you can update the frequency of your sine waves as necessary.
MarkT
Assuming bang-bang FOC isn't used...
And you can synchonize 3 PWM units on most Arduinos anyway - interrupt-driven duty cycle update can
be substituted for DMA.
