I am new to the arduino, and today was my first try at it.
I got a standard futaba servo up and running on pin 9 (external power supply), but when I try pin 6.. it does not work anymore, not even with the MegaServo library.
Please, what can I do to resolve this problem?, because some Arduino-Specialist dude at the Maker Faire, San Fransisco this year promised me that up to 12 servos would work on the Arduino Duemilanov.
And standard code from the arduino website doesn't work:
#include <MegaServo.h>
#define NBR_SERVOS 4 // the number of servos, up to 48 for Mega, 12 for other boards
#define FIRST_SERVO_PIN 5
MegaServo Servos[NBR_SERVOS] ; // max servos is 48 for mega, 12 for other boards
int pos = 0; // variable to store the servo position
int potPin = 0; // connect a pot to this pin.
for( int i =0; i < NBR_SERVOS; i++)
Servos[i].attach( FIRST_SERVO_PIN +i, 800, 2200);
pos = analogRead(potPin); // read a value from 0 to 1023
for( int i =0; i <NBR_SERVOS; i++)
Servos[i].write(90);
delay(15);
What do you expect to happen? Your last sketch reads the pot value but its not used, so the servos will not move once they are centered. Why not try the example sketch that comes with MegaServo. (change the value of FIRST_SERVO_PIN to 4) You should see the servo(s) sweep once then move to follow the pot value on analog pin 0
Hi NLStitch, “shocking/jibbering” are not words I have ever heard used to describe servo behavior, can you say more about what the servos are doing?
You may want to try reducing the range of movement in your attach function call just in case there is some mechanical binding at the extreme range. You can test if this is causing a problem by adding a command that centers all the servos :
Servos*.write(90);* If the servos center correctly then you need to fix the problem at the extremes of movement
switch (cmd) {
case 'f' :
Serial.print("Going Forward");
Servos[1].write(180);
case 'b' :
Serial.print("Going Backward");
Servos[1].write(0);
case 'l':
etc.
AWOL is giving good advice, as usual, but the form in the first suggestion
if('f' == cmd)
is not intuitive for a beginner and benefits from some explanation.
This expression does the same thing as the more obvious:
if(cmd == 'f' )
but putting the constant 'f' before the == allows the compiler to detect the common mistake of using a sign equals sign (setting the left hand side to be equal to the right) where an equality test was intended (testing to see if the left and right sides are equal). The compiler will report an error if you accidently do
if('f' = cmd) // error: single equal sign where == was intended
because 'f' is a constant (its equal to 102) and cannot be set equal to the value of the cmd variable.
Since I can only send my strings to the device using byte format in Java, I can't cast them back to strings in the Arduino to parse them like you suggested.(Or I missed something somewhere) That's why I am using numbers, because the Bytes received by the arduino can still be used as Integers. I know.. it looks like a really dirty hack and wrong way to accept and process data.. sigh .
What I meant with shocking of the servo's means that the servo's do "want" to get to their position at , let's say, 180, but its like they struggle to get there, and they only get there half if the wheel of the robot is on the ground, and full if the wheel is lifted from the ground.In both of these cases, it looks like they want to get back to there center as wel, like a clock or wristwatch that has an empty battery, going from left to right or right to left and only coming there half way.
The weird thing is, is when I used one with the Servo library at pin 9, it wasn't a problem.
NOTE: The 3 servo's ARE hooked up to a usb port of my laptop, and are therefore on a external power supply. So that should not be the problem.
That should be clear enough =). I hope you can help me.
'f' is not a string - it is a single character (byte) - the quotes are single quotes.
A string - "f" - uses double quotes and would consist of two characters, the character 'f and the character '\0'.
Then you need to put them on a supply capable of supplying sufficient current. Don't forget to connect the grounds.
The 'f', 'b' etc stuff was never going to cure the stuttering of the servos, just make your code easier to read.
If you've got a four-pack of fresh AA batteries or a bench supply capable of at least one amp at six volts, you could try powering the servos off those. Don't forget to common the grounds. (I wish I had a quid for every time I've typed that!)
You need to connect the Ground (0V or -ve terminal of a battery) of your external supply (batteries, whatever) to the ground (Gnd) pin on your Arduino.
okay, that grounding changed some things, but did not solve all the problems.. yet.
The steering servo is still jittering all the time, and the other servo's jitter when they position themselves or have to pull or push to "heavy" , (but these servo's are strong enough.. I had them on my R/C plane before.)
I have uploaded a small video that shows what this jittering means.. But the results are different, (see above) then showed in the vid. All servo's are working but are jittering when they adjust, and the steering servo is jittering all the time.
Video could still be processing, because it's new. Here it is:
Cheers,
NLStitch
P.S: The piece that connects all the + and - to the battery has an additional wire as well(and is not showed in the vid).. this wire is going from the ground there to a ground of the arduino.
OK, I have now seen the video. Can you try swapping the servo connections between the one that is jittering and one that is working ok. If the same servo jitters then try to actually swap the servos to see if it is problem with mechanical load.
You could also try disconnecting the mechanical load from all the servos and see if that stops the jittering.
Okay, rechecked all the wiring, all the servo's are working now but they are jittering when they want to get to their goal position.
I will try powering one servo with the power supply. If it works then I know that this power supply is not going to get all the servos working.
I do think it's strange if its the power supply, because this 4,8 volt pack worked like a charm powering -> 4 <- of these servo's in my r/c plane. I'm confused.
So, it's either a code problem, or a problem with the library. The servo is not jittering at all when using the Servo library.Both of these tests had the same power supply and the same servo(steering).
