Problem with my GY-521 gyroscope not working or wrong set up ?
Hi
i have this gyroscope that i am trying to get to work, i look up here arduino playground and copy the raw value code and the set up like this
SCL – A5
SDA – A4
VCC – 3.3V
GND – GND
AD0 – GND
INT – PIN2
but i don't know if that's the right config,
if anyone can help me i would appreciate it i apologize for my grammar and English.
:slight_smile:
Yes, that is okay for an Arduino Uno.
I think you don't have to connect AD0, there might already be a pullup or pulldown resistor on the sensor module.
Run the i2c_scanner, and it should find address 0x68 (or 0x69).
http://playground.arduino.cc/Main/I2cScanner
If that doesn't work, and you are very sure that there is a voltage regulator on the module, then apply 5V to VCC. But if the module does not have a voltage regulator, then the 5V will damage the sensor.
