HI Guys
I bought this 3-36v Dual 15a H-bridge DC Motor Driver 30a for Robot & Car Arduino Compatible for sale online | eBay h_bridge to try and make a wiper motor act like a big servo motor. Before I tried to get the wiper motor figured out I thought I would mess with a small motor first. I started by trying to write a sketch that would gradually speed a small motor up and then slow it down and then reverse the direction that the motor spins and cycle through the speed range again. I got this working and then I tried to add a flashing led to the sketch and the led would only flash ounce after the UNO went through the motor sketch before it would flash again. My question is can I make the led flash constantly while the motor is going through the sketch ?
Thanks GD
This is the first sketch I wrote to operate my H_Bridge
This gradually speed up and slowed down and then reversed
and repeated the slowing and speed back up
I included a blinking LED but it has to go through the
full cycle of the motor then it blinks ounce and goes back to
cycle through the motor sketch before blinking again
int led = 13; //pin 13 led blinking
int pwm = 9; //PWM on the H Bridge:
int dir = 8; //Dir on the H Bridge:
int i = 0; // We’ll use this to count up and down
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode (pwm, OUTPUT);
pinMode (dir,OUTPUT);
pinMode (led,OUTPUT);
// the loop routine runs over and over again forever:
void loop(){
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
digitalWrite(dir,HIGH);
for (i = 50; i < 255; i++) { // loop from 50 to 254 (fade in)
analogWrite(pwm, i); // set the LED brightness
delay(100); // Wait 10ms because analogWrite
// is instantaneous and we would
// not see any change
digitalWrite(dir,LOW);
for (i = 255; i > 50; i--) { // loop from 255 to 50 (fade out)
analogWrite(pwm, i); // set the pwm to control the motor speed---
delay(100); // Wait 100ms
