I am totally new to Arduino.
I just received a Diecimila, hooked it up to my PC running Windows XP, followed
the instructions to install the drivers, and attempted to upload the Blink example.
I received the following error:
java.lang.NullPointerException
at processing.app.Serial.setDTR(Serial.java:480)
at processing.app.Uploader.flushSerialBuffer(Uploader.java:76)
at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:69)
at processing.app.Sketch.upload(Sketch.java:1699)
at processing.app.Sketch.exportApplet(Sketch.java:1761)
at processing.app.Editor$42.run(Editor.java:1955)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
The green power LED is on and the orange LED is blinking (this means at least
the bootloader is working?). Is this a problem with the drivers? Some sort
of settings on my computer? I'm sorry if this is something that has been
posted on multiple times, but I couldn't find it in the forums or the
troubleshooting page. Thanks in advance.
Did you select the right serial port from the Tools | Serial Port menu? You want the that corresponds to the "USB-to-serial" entry in the Windows Device Manager. Also, if the port number is greater than 10, you should reassign it to a lower port.
I'm getting the same errors with my 2nd Diecimila. One works fine and runs Blink. If I unplug it from the USB and plug in the other and upload to I/O board I get the error dump. I can switch back to the first and it works fine so I don't think it's settings.
Well, I figured it out. It was the Serial port setting. Seems that when I unplug one board and plug in another the serial port assigned to the USB connector changes. I need to set it each time I plug in a board unless it is tied to a particular board in which case I need to know which board comes up as which port.
Windows changes port numbers again if you use different USB ports. But once you have defined a port number, to a specific Arduino board, plugged to a specific USB port, then you can switch Arduino boards and windows keeps the defined port number.
