Topic: Digital imput via arduino to processing (Read 9452 times) previous topic - next topic
AWOL
Quite so
Mein Luftkissenfahrzeug ist mit Aalen gefüllt
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
nickgammon
How about answering my questions in reply #14.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Sie haben schöne Oberschenkel.
nickgammon
Sorry, was bad coment, now I changed. How now ?
So far I haven't seen a single line of code that you have posted with the [ code ] tags as we have repeatedly requested. You want people to help you but are not prepared to take a couple of minutes to work out how to do that.
Your comments do not agree with the code you post. That shows a lack of attention to detail. Detail is what makes programs work. The computer cannot read your mind, nor can we. Code like this (bearing in mind the comments) show a total confusion on your part:
Quote
Code: [Select]
int switchPin = 4;                       // Switch connected to pin 4
  pinMode(switchPin, INPUT);      // Set pin 0 as an input
Meanwhile comments like this, while correct:
Quote
Code: [Select]
  if (val == 2) {              // If the serial value is 2,
... simply do not add anything at all to the code.
Imagine if I said this:
Code: [Select]
if (a == 2)   // if a is 2
What has the comment done? Has it helped in any way?
Or this:
Code: [Select]
a = 42;   // make a have the value 42
Try to think clearly. Programming is not about writing "stuff that looks like programs". It is about understanding what you are doing.
