SD card problem
i solving it like 80 % here is the code just trial code to show pictures from with sd card on website
//zoomkat 1/26/13
//SD server slider test code
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84/servosld.htm when submited
//for use with W5100 based ethernet shields
//put the servosld.htm, slider.js, bluev_sl.gif,
//and bluev_bg.gif on the SD card
//files at http://web.comporium.net/~shb/servoslider.htm page
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
String readString, pos;
int sensor;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x80, 0xA2 };
byte ip[] = {
  192, 168, 1, 102 }; // ip in lan
byte gateway[] = {
  192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
void setup(){
  pinMode(7,OUTPUT);
    pinMode(8,OUTPUT);
      pinMode(2,INPUT);
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD..");
  if(!SD.begin(4)) Serial.println("failed");
  else Serial.println("ok");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
         //select proper header for file to be sent to browser
          client.println("HTTP/1.1 200 OK"); //send new page
          if(readString.indexOf("index") >=0) {
          client.println(); }
           if(readString.indexOf("bk") >=0) {
          client.println("Content-Type: image/jpeg");
          client.println(); }
            File myFile = SD.open("bk.jpg");
            if (myFile) {
              while (myFile.available()) {
                client.write(myFile.read());
              myFile.close();
          if(readString.indexOf("d1") >=0) {
          client.println(); }
            File myFile = SD.open("d1.jpg");
            if (myFile) {
              myFile.close();
          //select file to send to browser
          if(readString.indexOf("index") >= 0) {
            File myFile = SD.open("index.HTM");
            if (myFile) {
              myFile.close();
          sensor=digitalRead(2);
   client.print(sensor);
         if(readString.indexOf('2') >0)//checks for 2
            //state1="ON";
            digitalWrite(8, HIGH);    // set pin 8 high
          if(readString.indexOf('3') >0)//checks for 3
            //state1="OFF";
            digitalWrite(8, LOW);    // set pin 8 low
          if(readString.indexOf('4') >0)//checks for 4
            //state2="ON";
            digitalWrite(7, HIGH);    // set pin 7 high
          if(readString.indexOf('5') >0)//checks for 5
            //state2="OFF";
            digitalWrite(7, LOW);    // set pin 7 low
          delay(1);
          //stopping client
          client.stop();
          readString="";
it worked good some how but when i press on ON button it lights the led but go to empty page so i must press back to the index.html
second problem the address now is 192.168.1.102:84/index.html i think it will make problem in port forwarding as i forward to port 84 only not 84/index.html how can i solve it ?
