And lastly, the modified header file:
#ifndef PID_Beta6b_h
#define PID_Beta6b_h
#define floatToFix(a) ((long)((a)*4096.0)) // mult by 2^12 to use floats in fixed point math
#define fixToFloat(a) ((double)((a)/4096.0)) // div by 2^12 to convert back to float
#define multFix(a,b) ((long)((((long)(a))*((long)(b)))>>12)) // bit-shift right 12 to maintain 12 assumed decimal places
#define divFix(a,b) ((long)(((long)(a)<<12)/((long)(b)))) // make Numerator 8:24 int before dividing
class PID
public:
#define AUTO 1
#define MANUAL 0
#define LIBRARY_VERSION 0.6b
//commonly used functions **************************************************************************
PID(double*, double*, double*, // * constructor. links the PID to the Input, Output, and
double, double, double); // Setpoint. Initial tuning parameters are also set here
PID(double*, double*, double*, // * Overloaded Constructor. if the user wants to implement
double*, double, double, double); // feed-forward
void SetMode(int Mode); // * sets PID to either Manual (0) or Auto (non-0)
void Compute(); // * performs the PID calculation. it should be
// called every time loop() cycles. ON/OFF and
// calculation frequency can be set using SetMode
// SetSampleTime respectively
void SetInputLimits(double, double); //Tells the PID what 0-100% are for the Input
void SetOutputLimits(double, double); //Tells the PID what 0-100% are for the Output
//available but not commonly used functions ********************************************************
void SetTunings(double, double, // * While most users will set the tunings once in the
double); // constructor, this function gives the user the option
// of changing tunings during runtime for Adaptive control
void SetSampleTime(int); // * sets the frequency, in Milliseconds, with which
// the PID calculation is performed. default is 1000
void Reset(); // * reinitializes controller internals. automatically
// called on a manual to auto transition
bool JustCalculated(); // * in certain situations, it helps to know when the PID has
// computed this bit will be true for one cycle after the
// pid calculation has occurred
//Status functions allow you to query current PID constants ***************************************
int GetMode();
double GetINMin();
double GetINMax();
double GetOUTMin();
double GetOUTMax();
int GetSampleTime();
double GetP_Param();
double GetI_Param();
double GetD_Param();
private:
void ConstructorCommon(double*, double*, double*, // * code that is shared by the constructors
//scaled, tweaked parameters we'll actually be using
long kc; // * (P)roportional Tuning Parameter
long taur; // * (I)ntegral Tuning Parameter
long taud; // * (D)erivative Tuning Parameter
//nice, pretty parameters we'll give back to the user if they ask what the tunings are
double P_Param;
double I_Param;
double D_Param;
double *myInput; // * Pointers to the Input, Output, and Setpoint variables
double *myOutput; // This creates a hard link between the variables and the
double *mySetpoint; // PID, freeing the user from having to constantly tell us
// what these values are. with pointers we'll just know.
long *myBias; // * Pointer to the External FeedForward bias, only used
// if the advanced constructor is used
bool UsingFeedForward; // * internal flag that tells us if we're using FeedForward or not
unsigned long nextCompTime; // * Helps us figure out when the PID Calculation needs to
// be performed next
// to determine when to compute next
unsigned long tSample; // * the frequency, in milliseconds, with which we want the
// the PID calculation to occur.
bool inAuto; // * Flag letting us know if we are in Automatic or not
long lastOutput; // * remembering the last output is used to prevent
// reset windup.
long lastInput; // * we need to remember the last Input Value so we can compute
// the derivative required for the D term
long accError; // * the (I)ntegral term is based on the sum of error over
// time. this variable keeps track of that
long bias; // * the base output from which the PID operates
long inMin, inSpan; // * input and output limits, and spans. used convert
long outMin, outSpan; // real world numbers into percent span, with which
// the PID algorithm is more comfortable.
bool justCalced; // * flag gets set for one cycle after the pid calculates
#endif
