I already did a lot of research.. I ended up reading Memory Areas and Using malloc which I quote:
A call to realloc() first determines whether the operation is about to grow or shrink the current allocation. When shrinking, the case is easy: the existing chunk is split, and the tail of the region that is no longer to be used is passed to the standard free() function for insertion into the freelist. Checks are first made whether the tail chunk is large enough to hold a chunk of its own at all, otherwise realloc() will simply do nothing, and return the original region.
When growing the region, it is first checked whether the existing allocation can be extended in-place. If so, this is done, and the original pointer is returned without copying any data contents. As a side-effect, this check will also record the size of the largest chunk on the freelist.
If the region cannot be extended in-place, but the old chunk is at the top of heap, and the above freelist walk did not reveal a large enough chunk on the freelist to satisfy the new request, an attempt is made to quickly extend this topmost chunk (and thus the heap), so no need arises to copy over the existing data. If there's no more space available in the heap (same check is done as in malloc()), the entire request will fail.
Otherwise, malloc() will be called with the new request size, the existing data will be copied over, and free() will be called on the old region.
The problem is that my real-world experience was not quite similar.. I found out that using grow/shrink procedures often resulted in random halts at runtime. And searching for similar problems a lot of people just say to stay away from dynamic memory allocation inside a uC system thing that I just can't understand. I mitigated my issue by not shrinking allocated memory and just procedural treat it has free with the help of accounting.
At the end of the day I was seeking for feedback from more experienced C/C++ programmers than I am.
