Arduino Forum
Using Arduino => Storage => Topic started by: fidamon on Aug 02, 2017, 10:58 pm
Title: SD card destroyed
Post by: fidamon on Aug 02, 2017, 10:58 pm
i made an arduino controlled GPS that writes to a file on SD card every 30 seconds my cars position
the problem is when i keep it working for more than 2 hours the Sd card is destroyed
on shorter drives (half an hour) it works properly
any hint ??
thank you
Title: Re: SD card destroyed
Post by: diogotec on Aug 03, 2017, 12:55 am
What do you mean "the SD card is destroyed"?
Also, give us more insight on what SD-card module u are using, the code you are using to save the data, etc!
Post by: Nick_Pyner on Aug 03, 2017, 04:25 am
It probably isn't. You either have a code problem, like use of Strings or something, or English is not your main language. Either way, the SD is almost certainly innocent.
Post by: fidamon on Aug 03, 2017, 08:26 pm
thanks for your replies
yes english  is not my first language
what i mean by SD card is destroyed : when i try to read  the file on it i get the message "this drive needs to be formatted " and it can't be formatted
the code i use :
 * //Function to write to File
void filereg(  ) {
  myFile = SD.open("history.txt", FILE_WRITE);
  Serial.println(RawStr);
     prevCompass = compassVal;
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to history.txt...");
    myFile.println(RawStr);
    // close the file:
    myFile.close();
    Serial.println("done.");
  } else {
    // if the file didn't open, print an error:
    Serial.println("error opening history.txt");
  if (SpeedStr.toInt()==0){
  writecount = -3000;}
  else {  writecount = 0;}
notice when i use it for a short while no broplem , the problem happens in long distance
and i am sure the SD card is inoccent
thanks again
Post by: el_supremo on Aug 03, 2017, 10:59 pm
the code i use
That is only a small snippet from the code that you use. Post all of it.
This suggests that you are using the String class.
That is a common symptom of running out of ram. Using the String class (as has been mentioned) is often a problem.
But unless you post all your code, we're all just guessing.
Pete
Post by: Nick_Pyner on Aug 04, 2017, 02:40 am
Have you checked
http://forum.arduino.cc/index.php?topic=228201.0
Get rid of Strings. A simple myfile.print(variable); usually suffices and will run for as long as there is space on  the card.
Post by: fidamon on Aug 04, 2017, 04:07 pm
well that is my code
 /* SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 10
#include <SPI.h>
#include <SD.h>
#include <LiquidCrystal.h>
#include <string.h>
#include <ctype.h>
//#include <SoftwareSerial.h>
// initialize the library with the numbers of the interface pins
//SoftwareSerial mySerial(2, 3); // RX, TX
//LiquidCrystal lcd(12, 13, A0, A1, A2, A3);
LiquidCrystal lcd(18, 19, 14, 15, 16, 17);
bool    cardfound = false;
File    myFile;
int     writecount = 0;
char    linea[250] = " ";
int     prevCompass = 0;
int     compassVal = 0;
int     cont = 0;
int     conta = 0;
int     indices[13];
String  RawStr = "";
//String  filenam = "";
String  Hstr = "$GPRMC";
String  LatStr = "";
String  TimeStr = "";
String  SpeedStr = "";
String  compastr = "";
String  LonStr = "";
String  OKStr =  "";
 * //setup
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  //mySerial.begin(9600);
  pinMode(9, OUTPUT);
  digitalWrite(9 , HIGH);
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    LCDKP( 0 , 0 , "initialization  "  , true );
    LCDKP( 0 , 1 , "failed! "  , false );
    return;
  //  Serial.println(cardfound );
else {
  Serial.println("initialization done.");
  cardfound = true ;
  LCDKP( 0 , 0 , "Memory initiated" , true );
  LCDKP( 0 , 1 , "Fidamon Systems" , false );
/***********press button to change display***************************/
  pinMode(7, OUTPUT);
 digitalWrite(7 , HIGH);
 pinMode(5, OUTPUT);
 digitalWrite(5 , LOW);
 pinMode(6, INPUT);
 // re-open the file for reading:
  myFile = SD.open("history.txt");
//  myFile = SD.open(filenam);
  if (myFile) {
    Serial.println("history.txt :");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  if (digitalRead(6) == LOW) { writecount=131;  }
// if (mySerial.available()) {
   if (Serial.available()) {
   //   Serial.write(mySerial.read());
 //   linea[conta] = mySerial.read();      // If there is serial port data, it is put in the buffer
     linea[conta] = Serial.read();      // If there is serial port data, it is put in the buffer
   conta++;
    if (linea[conta - 1] == 13) {       // If the received byte is = to 13, end of transmission
      RawStr = String(linea);
      // note: the actual end of transmission is <CR><LF> (i.e. 0x13 0x10)
      //Serial.println("");
      Hstr = RawStr.substring(1, 7);
      cont = 0;
      conta = 0;
      //  bien = 0;
    if (Hstr == "$GPRMC") {
      for (int i = 0; i < 250; i++) {
        indices[cont] = 0;
        if (linea[i] == ',') { // check for the position of the  "," separator
          // note: again, there is a potential buffer overflow here!
          indices[cont] = i;
          cont++;
        if (linea[i] == '*') { // ... and the "*"
          indices[12] = i;
          cont++;
          i = 301;
           RawStr = RawStr.substring(1, indices[12] + 2);
      RawStr.trim();
      TimeStr = RawStr.substring(indices[0], indices[1]);
      OKStr = RawStr.substring(indices[1], indices[2] - 1);
      LatStr = RawStr.substring(indices[2]  , indices[4]-1);
      LonStr = RawStr.substring(indices[4] , indices[6]-1);
      SpeedStr = RawStr.substring(indices[6], indices[7]);
      compastr = RawStr.substring(indices[7], indices[8]);
        TimeStr = loctime(TimeStr, LonStr) ;
    compassVal=compastr.toInt();
//       if (abs(prevCompass - compassVal)>45){writecount=231;}
      compastr =directionS (compassVal);
      SpeedStr = String(speedkph(SpeedStr.toFloat()));
      if (SpeedStr.toInt()>0){
      if (writecount<0){  writecount += 3000;}}
         RawStr = RawStr.substring(indices[8] , indices[9]-1);
RawStr =  TimeStr + "," + OKStr + "," + LatStr + "," + LonStr  + "," + SpeedStr  + "," + compastr  + "," + RawStr   + "," +  writecount ;
      writecount += 1;
      if (writecount > 30)      {  filereg( );      }
   switch (writecount) {
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
             LCDKP( 0 , 0 , "Lon " + LonStr , true );
                LCDKP( 0 , 1 , "Lat  " +  LatStr , false );
             LCDKP( 3 , 1 ,   OKStr , false );
        break;
        default:
      LCDKP( 0 , 0 , "Tim " + TimeStr , true );
       LCDKP( 14 , 0 ,  String( writecount) , false );
      LCDKP( 15 , 0 ,   OKStr , false );
     LCDKP( 0 , 1 , "Spd " +  SpeedStr  + " "  +  compastr , false );
           break;  }
      Hstr = "";
      for (int i = 0; i < 250; i++) { //
        linea[i] = 0;
 * //Function to werite to LCD
void LCDKP(int col , int row, String prntstr , boolean cls ) {
  if (cls == true) {
    lcd.clear();
  lcd.setCursor(col, row);
  lcd.print(prntstr);
 * //Function to calculate the speed in Kilometer per hour
float speedkph(float knots)
  float kmfactor = 0.556;
  float kmphour = 0;
  kmphour = knots / kmfactor;
  return kmphour;
void filereg(  ) {
  if (myFile) {
    // close the file:
    myFile.close();
Post by: el_supremo on Aug 04, 2017, 05:42 pm
That code does not compile.
Pete
Post by: fidamon on Aug 04, 2017, 05:51 pm
i had to  dlete parts because  it woos too big for the forum
Post by: fidamon on Aug 04, 2017, 05:57 pm
part 1 from code
* LCD RS pin to       pin A4
* LCD Enable pin to   pin A5
* LCD D4 pin to       pin A3
* LCD D5 pin to       pin A2
* LCD D6 pin to       pin A1
* LCD D7 pin to       pin A0
* LCD R/W pin to ground
* 10K resistor:
* ends to Vin and ground
* wiper to LCD VO pin (pin 3)
Example code for connecting a Parallax GPS module to the Arduino
Listen for the $GPRMC string and extract the GPS location data from this.
Display the result in the Arduino's serial monitor.
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10
#include <SPI.h>
#include <SD.h>
#include <string.h>
#include <ctype.h>
File    myFile;
int     writecount = 0;
int     compassVal = 0;
int     cont = 0;
int     conta = 0;
int     indices[13];
String  RawStr = "";
String  LatStr = "";
String  LonStr = "";
String  OKStr =  "";
* //setup
lcd.begin(16, 2);
pinMode(9, OUTPUT);
 return;
else {
cardfound = true ;
pinMode(7, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, INPUT);
if (myFile) {
 // close the file:
 myFile.close();
* //loop
conta++;
   cont = 0;
   conta = 0;
   //  bien = 0;
   // check for the position of the  "," separator*******************************************************
     indices[cont] = 0;
       indices[cont] = i;
       cont++;
       indices[12] = i;
       cont++;
       i = 301;
   RawStr.trim();
//      LatStr =MintoDec("0"+LatStr );
//      LonStr =MintoDec(LonStr );
  // filenam = RawStr.substring(indices[8] , indices[9]-1);
  // filenam =filenam + ".txt";
   writecount += 1;
   case 2:
   case 3:
   case 4:
   case 5:
   case 6:
     break;
     default:
        break;  }
   Hstr = "";
     linea[i] = 0;
Post by: el_supremo on Aug 04, 2017, 06:07 pm
Add the code tags
Pete
Post by: fidamon on Aug 04, 2017, 06:11 pm
my code part 2
  if (cls == true) {
    lcd.clear();
  lcd.print(prntstr);
 * //Function to calculate the distance between two waypoints
float calc_dist(float flat1, float flon1, float flat2, float flon2)
  float dist_calc = 0;
  float dist_calc2 = 0;
  float diflat = 0;
  float diflon = 0;
  //I've to spplit all the calculation in several steps. If i try to do it in a single line the arduino will explode.
  diflat = radians(flat2 - flat1);
  flat1 = radians(flat1);
  flat2 = radians(flat2);
  diflon = radians((flon2) - (flon1));
  dist_calc = (sin(diflat / 2.0) * sin(diflat / 2.0));
  dist_calc2 = cos(flat1);
  dist_calc2 *= cos(flat2);
  dist_calc2 *= sin(diflon / 2.0);
  dist_calc += dist_calc2;
  dist_calc = (2 * atan2(sqrt(dist_calc), sqrt(1.0 - dist_calc)));
  dist_calc *= 6371000.0; //Converting to meters
  return dist_calc;
  float kmphour = 0;
  return kmphour;
 * //Function to calculate the local time
String loctime(String gpsTime, String lonstr)
  String mytime = "";
  int hrs = 0;
  int mnts = 0;
  int scnds = 0;
  int grntsh = 0;
  hrs = gpsTime.substring(0, 2).toInt();
  mnts = gpsTime.substring(2, 4).toInt();
  scnds = gpsTime.substring(4, 6).toInt();
  grntsh = lonstr.substring(0, 3).toInt();
  grntsh *= 4;
  mnts += grntsh;
  grntsh = mnts / 60 ;
  mnts %= 60;
  hrs += grntsh;
  if (hrs > 23)
    hrs -= 24;
  if (hrs > 12)
    hrs -= 12;
  if (hrs < 10)
    mytime =  "0";
  mytime = mytime + String(hrs) + ":";
  if (mnts < 10)
    mytime = mytime + "0";
  mytime = mytime + String(mnts) + ":";
  if (scnds < 10)
  mytime = mytime + String(scnds);
  return mytime;
 * //Function to calculate the cheksum
String cheskStr (String rawstr)
  int checksum = 0 ;
  for (int i = indices[0]; i < indices[12]; i++) {
    //     checksum = checksum Xor Convert.ToByte(Character)
  //Function to calculate Direction
String directionS (int compassa)
  String mydirect = "";
  if (compassa > 357) {
    mydirect = "N";
  else {
    if (compassa > 315) {
      mydirect = "N " + String(360 - compassa) + " W" ;
    else {
      if (compassa > 272) {
        mydirect = "W " + String( compassa - 270) + " N" ;
      else {
        if (compassa > 268) {
          mydirect = "W "  ;
        else {
          if (compassa > 225) {
            mydirect = "W " + String(270 - compassa) + " S" ;
          else {
            if (compassa > 182) {
              mydirect = "S " + String( compassa - 180) + " W" ;
            else {
              if (compassa > 178) {
                mydirect = "S " ;
              else {
                if (compassa > 135) {
                  mydirect = "S " + String(180 - compassa) + " E" ;
                else {
                  if (compassa > 92) {
                    mydirect = "E " + String( compassa - 90) + " S" ;
                  else {
                    if (compassa > 88) {
                      mydirect = "E ";
                    else {
                      if (compassa > 45) {
                        mydirect = "E " + String(90 - compassa) + " N" ;
                      else {
                        if (compassa > 2) {
                          mydirect = "N " + String(  compassa) + " E" ;
                        else {
                          mydirect = "N ";
  return mydirect;
void filereg(  ) {
  if (myFile) {
    // close the file:
    myFile.close();
  } else {
 * //Function to Convert from degres minutes to decimal
String MintoDec(String xx   )
  String ss= xx;
int intVal= ss.toInt();
ss.replace(".", "");
intVal =intVal /100 ;
ss =ss.substring(3);
ss.trim() ;
int MinVal= ss.toInt();
MinVal = MinVal * 100 / 60;
ss =String(intVal)+ "." + String(MinVal) ;
return  ss ;
Post by: el_supremo on Aug 04, 2017, 06:53 pm
Add code tags to your message #9. Just highlight all the code and hit the </> icon.
Pete
Post by: pito on Aug 05, 2017, 04:37 pm
Not related to your issue - I would recommend you to use double with your float calcs.
Post by: el_supremo on Aug 05, 2017, 06:29 pm
In part 1 of your code there is an extra }. Delete the } at the end of that file.
If you are using a NANO or UNO or similar, I suspect that your use of the String class is causing the problem.
Change all uses of the String class to C strings and it should solve the problem.
Pete
Post by: jremington on Aug 07, 2017, 02:16 am
Electrical systems in cars are extremely noisy and can destroy unprotected electronics.
Post a wiring diagram.
Post by: fidamon on Aug 07, 2017, 07:12 pm
Pete
i'll be more thankful if you send a link about the  C strings or an example
and how does a ram problem destroy the SD card hardware that it become unformattable
Post by: sterretje on Aug 11, 2017, 08:27 pm
What kind of cardreader do you use with the Arduino?
SD cards are 3.3V; using 5V power and signals can damage it after a while.
Post by: fidamon on Aug 22, 2017, 02:33 pm
Thank you all for your answers
i think a very helping site is :>
http://gammon.com.au/forum/bbshowpost.php?bbsubject_id=12112
