Topic: Arduino.org now redirects to Arduino.cc (Read 6166 times) previous topic - next topic
mastrolinux
@pert we do not have access to http://www.arduino.org.cn yet but  we are working on it and will update you here.  It could take months before we will be able to access it.
I do not have info yet about the github organization but as soon as I will have info will write here again.
I am going to share a trick to retrieve data from .org servers but I do not know how long they will be online. You can put on your hosts file the following line:
162.217.98.42 download.arduino.org www.arduino.org
That should be enough in the interim.
pert
@mastrolinux, it was reported on the issue tracker:
https://github.com/arduino/Arduino/issues/6790
that the schematic link on the Leonardo ETH product page:
https://store.arduino.cc/usa/arduino-leonardo-eth
still points to the arduino.org link:
http://download.arduino.org/products/LEONARDOETH/Arduino_Leonardo_Eth_V1_sch.pdf
which just redirects back to the arduino.cc homepage
I discovered the correct URL for that file is:
https://www.arduino.cc/en/uploads/Main/Arduino_Leonardo_Eth_V1_sch.pdf
The Eagle file link has the same problem:
http://download.arduino.org/products/LEONARDOETH/Arduino_Leonardo_Eth_V1_rd.zip
The correct URL:
https://www.arduino.cc/en/uploads/Main/Arduino_Leonardo_Eth_V1_rd.zip
Isaac96
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
pert
Somebody copied the wrong page  https://cdn.arduino.cc/reference/en/language/functions/characters/isspace/
Syntax is wrong
should be
Code: [Select]
isSpace(thisChar)
Thanks for reporting this! I have submitted a fix for it:
https://github.com/arduino/reference-en/pull/133
FYI, this is not the correct place to report this sort of issue. This thread is specifically for reporting missing arduino.org content. It's much appreciated if you will point out any issues you find with the new reference pages but in the future please do so by creating a new topic in the appropriate forum section.
pert
My pull request has just been merged so the isSpace() reference issue is now fixed.
