reading sms
Change some of your code to look like this:
        Serial.print("data: [");
        Serial.print(data);    //shows the message
        Serial.println("]");
        if(strcmp(data, "on") == 0)
           Serial.println("Turning LED on");
           digitalWrite(led,HIGH);
        if(strcmp(data, "off") == 0)
           Serial.println("Turning LED off");
           digitalWrite(led,LOW); // Turn the pin off
Show us the serial output.
after adding parts to the sketch,
"I changed my code, but I'm not going to show it to you." Did I paraphrase that correctly?
when i send sms's it works perfectly,but i have problems reading sms's and activating outputs,for some reason the loop in the sketch stops after the first check when ever i try to read the serial data,
And, yet, still no code.
maybe my delete command wrong;
One can help with coding without understanding which AT command does what. You should have functions that send exactly one AT command. The name of the function should clearly reflect what the AT command being sent does.
If
  Serial.println("AT+CMGR");    //Reads the first SMS
reads the message, and
  Serial.println("AT+CMGD=1,4");
deletes it, then, yes, you have a problem with the delete command.
data no longer gets a value, because you no longer actually read anything. So, the fact that sending the Arduino a SMS causes nothing to happen is not really surprising.
"OK, I made some more code changes that I'm not going to show you..." Haven't we been down this path before?
We can NOT see what you are doing.
We've hired a psychic, but he's not due to start until the 12th of never. Until then, you have to help out.
  while(Serial.available()==0);
Send a command. Wait until there is a reply. Ignore the reply. Expect, magically, the data to have been read anyway.
Can anyone else see a problem with this?
What happened to the code to actually read the reply?
ok,this is my full code,does not loop when checking for sms's,
What output do you get?
Why is that Serial.flush() back? GET RID OF IT!!!
stops checking after ;
You don't know that. All you know is that your reading loop never ends. So, what is happening in that loop?
  for (x=0;x < 255;x++){
    data[x]='\0';
If you understood C strings, you'd know why this was unnecessary.
data[0] = '\0';
is all that is needed.
Make some changes.
x=0;
do{
data[x++]=Serial.read();
data[ x ] = '\0'; // Keep string NULL terminated
if(data[x-1]==0x0D&&data[x-2]=='"')
{ // Down here where it belongs!
x=0;
data[ 0 ] = '\0';
Serial.print(data);
while(!(data[x-1]=='K'&&data[x-2]=='O'));
Show us the output (and the code).
  x=0;
  do{
How valid do you suppose -1 and -2 are as indices into data?
You really need to ditch the do/while loop, and use some other construct to wait for data, and then read all data until OK appears. But, before you get started on that, think about what happens if the AT command fails, and the return does NOT include OK.
all i have is this perfect code
        x=0;
        do{
        }while(!(data[x-1]=='K'&&data[x-2]=='O'));
When x is 0, as it is initially, it gets incremented to 1 inside the body of the do/while statement. Then, at then end you check the values in data[ 0 ] and data[ -1 ], to see if they are O and K. And, you call code that references an invalid element of the array "perfect". I don't think so.
Add the if(strcmp(data, "on") == 0) block to that code. After the if block, print data again. With the '[' before and ']' after it. Does data get corrupted by the strcmp() call?
hi sir, not sure if its done correctly but there's my attempt,
yes the data does get corrupted.
No, it doesn't. If it did, the output would be correct before the if statement, and corrupt after. It is not correct at any point.
The fact that you are trying to talk to the phone and the PC on the same serial port is the problem.
found a sketch for sim900,that should activate led pin output when receives an sms with on but does not,my serial monitors shows the sketch reading the sms without any problems but no led lights up.Got the gsm shield set on software serial and using uno R3,also tried using it in hardware serial mode,did not work,in hardware serial mode pin1 and 2 are (txrx),not sure how to re-configure in the sketch and not sure why led is not high when sms with ,on is sent.
Look through the output you showed. Where do you see "on" or "off" in that output?
The below web code shows how to capture an incomming string and see if it contains an "on' or "off", then act appropriately. Might have something useful for you.
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  server.begin();
  //enable serial data print
  Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //see what was captured
          //now output HTML data header
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
          client.println("Pin 5 'on' or 'off': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
          client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
          client.println("</FORM>");
          client.println("
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
this sketch reads incoming sms's and stores it perfectly,the stored sms  doesnt show the contents of it,the word 'on' doesnt appear anywhere on the serial monitor only the cellphone number and some other details,according to the sketch it should activate the led when an sms 'on' is sent,i checked all AT commands they seem to be right,not sure how to modify the part that is responsible for reading the sms,
The is NOT code. Learn how to post comments OUTSIDE of the code tags.
    if(Serial.available())
    else  if(mySerial.available())
Why are these exclusive?
        char SerialInByte;
        SerialInByte = (unsigned char)mySerial.read();
Why are you separating the declaration and the initialization?
        char SerialInByte = (unsigned char)mySerial.read();
Casting to an unsigned char to store in a signed char is a bad idea, by the way. The cast is not needed at all.
        // FR: Si le message se termine par un <CR> alors traiter le message
        if( SerialInByte == 13 ){
Why not make it clear what the code is doing?
        if( SerialInByte == '\n' ){
If you can add a space after the open parenthesis, why can't you add one after the close parenthesis? Studying the code every time is a waste of time. Organize the code so it is readable.
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
Again, why not make the code clearer?
         if( SerialInByte == '\r' ) {
           msg += String(SerialInByte);
Invoking the constructor, the copy constructor, the assignment operator, and the destructor for the String class to add one character is a waste of resources. The += operator is overloaded to add a character. Use that overload instead of converting the one character to a new String.
In fact, you should get rid of the String class, altogether.
Anyway, none of this has anything to do with why the AT commands are not returning entirely what you expect. That doesn't mean that they should not be fixed. What it tells me is that you are issuing the wrong AT command to read the SMS.
I'm fighting with a similar issue. I have a bit different code, and yes, it is far away from optimized or good-looking or professional etc. code. But, never mind, it works almost. I took it from the GeeTech GPRS module wiki page and made some modifications.
This code waits and reacts when a new SMS has received. It reads it (or try to read) and in the future it should do something based on the message content and then delete it. Currently it only deletes it. This part works, it notices a new SMS, reads it and deletes it. Next SMS works similar way.
The problem is in the message itself. If I send a SMS "Testing", only part of it will be displayed, like in the example output below, there is only "Test". If I wrote a longer SMS, the result is not truncated but contains random letters from the SMS sent. Any ideas why?
All I want is to get it working, may the code be brilliant or not :slight_smile:
#include <SoftwareSerial.h>
#include <string.h>
SoftwareSerial GSM(7, 8);
char buffer[300];
boolean clear = true;
int count=0;
void setup ()
  GSM.begin (19200);
  Serial.begin (19200);
  delay (4000);
void ClearBufferArray ()
  for (int i=0; i<count; i++)
      buffer[i] = NULL;
void loop ()
  if (clear) {
// First delete possibly existing messages and put into text mode
// Somehow these does not work in Setup (), maybe...
    GSM.println ("AT+CMGD=1,4");
    clear = false;
    Serial.println ("Existing SMSs deleted");
    delay (1000);
    GSM.println ("AT+CMGF=1");
    Serial.println ("Text mode");
  if (GSM.available()) {
//Read data from GSM into buffer
    while (GSM.available ()) {
      buffer[count++] = GSM.read ();
      buffer[count] = '\0';
// Avoid overflow
      if(count == 300)
        break;
//New message arrives, print the message announcement
    if (strstr (buffer,"+CMTI:")) {
      Serial.println ("SMS Received");
// Send reading command to GSM
      GSM.println ("AT+CMGR=1");
// Handle the message
    if (strstr (buffer,"+CMGR:")) {
// So far only print the new one and delete it (all)
      Serial.println ("Reading SMS");
// If no more data, transmission ends, print the buffer
    Serial.println (buffer);
    ClearBufferArray ();
    count = 0;
  if (Serial.available ())
    GSM.write (Serial.read ());
And output:
Text mode
AT+CMGD=1,4
OK
AT+CMGF=1
OK
SMS Received
+CMTI: "SM",1
AT+CMGR=1
Reading SMS
+CMGR: "REC UNREAD","+358405833XXX","","13/01/21,23:56:46+08"
Test
OK
AT+CMGD=1,4
OK
MikkoR:
			// Avoid overflow
			if(count == 300)
			break;
I doubt that it is causing you any problems, but for robustness you should do the overflow check before appending the received character to the buffer rather than after.
In your message handling code you assume that a complete message has been received as soon as GSM.available() returns zero, but all that really means is that the Arduino is reading characters from the serial connection faster than the GSM module is writing them. You should keep reading until you know you have received the complete response to your command. I don't know why you're seeing garbled messages but the fact you may only be reading the first few characters of each response from the GSM module could mean that the serial connection is overflowing at the sending side so perhaps that is the problem. In any case you need to sort out the serial port handling here before you look for any further problems.
PeterH:
Sounds very reasonable, but how can I be sure that the serial input is actually finished? I'm not so familiar with these. Or should I read until "\nOK" is received? I think it is in the end of the message given by AT command (if everything goes right). Adding some delay did not work and is not a good idea anyway.
MikkoR:
A delay is certainly not the way to do it, agreed.
You need to work out how to detect the end of the response. If you know that each command response is followed by "\nOK\n" then you could wait until you receive that.
Sorry for bumping an old thread but Google led me here so this might help others.
You are probably overflowing the SoftwareSerial buffer which is set to 64 bytes.
You can confirm this by checking GSM.overflow() returns true
(reference http://arduino.cc/en/Reference/SoftwareSerialOverflow)
A dirty hack is to increase the SoftwareSerial buffer. Under libraries/SoftwareSerial/SoftwareSerial.h you'll find this line:
#define _SS_MAX_RX_BUFF 64 // RX buffer size
Increase it, keeping in mind the SRAM limitations on your Arduino device.
Edit:
After playing around a bit more I found the following in addition:
  • I had to change _SS_MAX_RX_BUFF directly in the SoftwareSerial.h class. Trying to #define it in my own project (either before or after the #include) resulted in failures still. I'm not sure why...printing out _SS_MAX_RX_BUFF and doing a sizeof(_receive_buffer) matched my values but it was still overflowing at 64.
  • I get corruption if I use any buffer size that isn't a power of 2. I don't know why.
  • To use a buffer size over 255 (well, 128) the variables _receive_buffer_tail and _receive_buffer_head need to be changed from uint8_t to uint16_t. I couldn't go above 128 without making that change.
Some reference info related to the two above things I found at SoftwareSerial Buffer problem when not power of 2 - #4 by nickgammon - Programming Questions - Arduino Forum
Hello,
Has someone come up with a solution with the above stated problem?
We are using Arduino Duemilanove and SIM 900 GSM module (http://robokits.co.in/shop/index.php?main_page=product_info&products_id=303)
We've tried to work on the similar problem of lightning Leds from port 9-12 when we send an sms #aibicidi, where i = 0 or 1, 0 =off, 1=on.
Eg. #a1b1c1d1 will switch on all the Led's.
When we upload the code and run it through serial monitor and enter the #a1b1c1d1 in the serial monitor, we can see all the led's lighten up. But if we send the sms with having content "#a1b1c1d1", we dont see any function of leds.
It would be great if anyone can give some guidance about the same.
 char inchar; //Will hold the incoming character from the Serial Port.
 int led1 = 9;
 int led2 = 10;
 int led3 = 11;
 int led4 = 12;
 // prepare the digital output pins
 pinMode(led1, OUTPUT);
 pinMode(led2, OUTPUT);
 pinMode(led3, OUTPUT);
 pinMode(led4, OUTPUT);
 digitalWrite(led1, LOW);
 digitalWrite(led2, LOW);
 digitalWrite(led3, LOW);
 digitalWrite(led4, LOW);
 //Initialize GSM module serial port for communication.
 delay(3000); // give time for GSM module to register on network etc.
 Serial.println("AT+CMGF=1"); // set SMS mode to text
 delay(200);
 Serial.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
 delay(200);
 //If #a1b1c1d1 comes as sms, all led's should light up.
 if(Serial.available() >0)
 inchar=Serial.read();
 if (inchar=='#')
   delay(10);
 //first led
   if (inchar=='a')
   delay(10);
 if (inchar=='0')
 else if (inchar=='1')
   digitalWrite(led1, HIGH);
 delay(10);
 //Second led
 if (inchar=='b')
 if (inchar=='0')
 digitalWrite(led2, HIGH);
 delay(10);
 // Third led
 if (inchar=='c')
 if (inchar=='0')
 digitalWrite(led3, HIGH);
 delay(10);
 //Fourth led
 if (inchar=='d')
 delay(10);
 if (inchar=='0')
 digitalWrite(led4, HIGH);
 delay(10);
 Serial.println("AT+CMGD=1,4"); // delete all SMS
We were able to lighten up the LED with an sms.
Keeping the code below. This code will lighten 9 leds which are kept from port 4 to 12. The sms code is "0#iii#iii#iii, where i =0 or 1 meaning off or on respectively. Ex. 0#111#111#111 will switch on all the leds.
The modification was AT+CNMI=2,2,0,0,0 instead of AT+CNMI=3,3,0,0 from our previous code.
 int led1 = 4;
 int led2 = 5;
 int led3 = 6;
 int led4 = 7;
 int led5 = 8;
 int led6 = 9;
 int led7 = 10;
 int led8 = 11;
 int led9 = 12;
 pinMode(led5, OUTPUT);
 pinMode(led6, OUTPUT);
 pinMode(led7, OUTPUT);
 pinMode(led8, OUTPUT);
 pinMode(led9, OUTPUT);
 // initially all are off
 digitalWrite(led5, LOW);
 digitalWrite(led6, LOW);
 digitalWrite(led7, LOW);
 digitalWrite(led8, LOW);
 digitalWrite(led9, LOW);
 Serial.println("AT+CMGF=1\r"); // set SMS mode to text
 delay(200);
 Serial.println("AT+CSMS=1\r");
 delay(200);
// Serial.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
 Serial.println("AT+CNMI=2,2,0,0,0"); // set module to send SMS data to serial out upon receipt
 delay(200);
 //If a character comes in from the Serialular module...
 delay(10);
 if (inchar=='0')   // to catch the 1st 0 in our string 0#101#101#101
       // digitalWrite(13, HIGH);
       // for #101________________
       inchar=Serial.read(); // read next char i.e '#'
       if (inchar=='#')
             inchar=Serial.read(); //read next char i.e 1
             if (inchar=='0')
       delay(10);
             inchar=Serial.read(); //read next char i.e 0
             if (inchar=='0')
       delay(10);
             if (inchar=='0')
       } //end of  1st 'if char==#' loop
       //for _____  #101  _______
       if (inchar=='#')
             if (inchar=='0')
       delay(10);
             if (inchar=='0')
                 digitalWrite(led5, HIGH);
       delay(10);
             if (inchar=='0')
                 digitalWrite(led6, HIGH);
       } //end of 2nd 'if char==#' loop
       //for _____ _____ #101
       if (inchar=='#')
             if (inchar=='0')
                 digitalWrite(led7, HIGH);
       delay(10);
             if (inchar=='0')
                 digitalWrite(led8, HIGH);
       delay(10);
             if (inchar=='0')
                 digitalWrite(led9, HIGH);
       } //end of 3rd 'if char==#' loop
 } // "ckeck 0 in front of string" wala loop close
 //Serial.println("AT+CMGD=1,4"); // delete all SMS
 } // serial available condition close
//   Serial.println("AT+CMGR=1\r");
//   delay(4000);
 } // LOOP function close
