The stamped steel sensors on Ebay are the cheapest. You might need to spread the load over multiple sensors to get the 100Kg load bearing capability.
With a suitable enclosure there's no need for the load cell to be exposed to the weather. High humidity and temperature gradients are your main concerns.
Apply a liberal coating of bituminous paint then re-calibrate over the required temperature range.
Compensate for long term drift by setting up a duplicate system that you can fit with a series of known weights.
30g resolution outdoors it going to be tricky as the wind can easily apply that sort of positive/negative lift force depending on the shape of the thing you are weighing.
TolpuddleSartre:
30g over 100kg implies an ADC resolution of at least 12 bits.
Are you using a Due?
Nope, i am using UNO so maybe i need change the board or buy a adc 12 bit resolution.
¿Some ideas, what the best/cheaper ways?
Wawa:
I assume OP will use a HX711 breakout board.
Leo..
Yes i will use HX711 and load cell from a scale.
mikb55:
How can do that? i mean when the sensor is there, i can't remove the weight off the scale. There are some system to do that without remove the weight off?
