Capacitance does matter in case your problem is like mine was.
If you need a longer reset, you can either use a higher resistance, or a larger capacity.
Both accomplish a longer time to charge the capacitor to reach a higher voltage level so reset ends (reset is most of the times active low).
But as you need to keep pressure applied, this is not the case for you.
You probably have a poor soldering somewhere on the board.
