For that I would have to move mega to the outside and now is already night here in portugal.
I shell do it tomorow morning.
Can I do any more testing meanwhile ?
José
José
I might be able to get everything working by slowing up all SPI devices. Want to try that?
Sure.
At this moment I am whilling to try anything.
By the way whats the problem of having low speed SPI ?
José
Transfer rate is the big drawback. However, if this is a custom application, you can limit the size of the transfers to keep the time required relatively the same.
After the Serial.begin() call in setup(), add this
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV32);
This should reduce the w5100 to 512KHz. Does the w5100 get an ip? If it does, comment out the two SPI speed changes in readMax().
Hi
No Luck
No sd card and no IP.
José
That is the best I can do. That should have worked if it was just the long wire runs. It seems like it is your MISO line may not release on the 6675.
You can try reducing the wire lengths, but I'm not sure that will help after these tests.
I just remember I have an arduino duemilanove and tomorow I will try to use it next to the sensor do avoid the wire being so long.
I will post the results then.
José
I forgot to mention one thing you might check. Insure you are getting the correct voltage on the Max6675 CS pin on the device itself. The connection may have broken somewhere.
edit: Also check there are no devices (logic level converter or similar) between the 6675 SO pin and the Arduino.
It appears the max6675 is working ok, but not releasing the MISO line. Either of these conditions would cause this problem.
Hello
Sorry for my silence but my litle girl is not been so well.
Today I checked the cable, there is a connection in the meadle, and the results were the same.
Tomorow I will check the board. It was me you made the connections to the MAX6675 IC and there may be a short circuit somewhere.
I will check the voltage as you sugested.
José
Hope your little girl is doing better.
Do you have an o-scope? If so, I would check the MISO line with the max disconnected, then connected.
If not, I would use a voltmeter and a 1K resistor to determine if the max is releasing the MISO line. Connect the voltmeter to measure voltage at SO on the max, and connect the CS line to 5v. The MISO pin on the max should be high impedance at this point.
Then use a 1K resistor in series from the SO line on the max to GND, then 5v. The voltage on the SO should change according to the voltage applied to the resistor. If it doesn't, it is not releasing the MISO line.
Not sure if I understand what you mean.
I do not have an o-scope its on my shopping list. By the way may you sugest a good o-scope for a beginner ?
Between the So and ground right ?
Directly or with the resistor ?
What do yo mean by high impedance ?
José
Hello
With the code from post #63 I have 3.24v between so and ground. Is this ok ?
José
Ps. For further testing I will have to completly disconnect the max and because is already night here I have to wait for the weekend.
With the CS pin is HIGH (5v), the SO pin should be high impedance. That means it doesn't try to drive the MISO line HIGH or LOW. It becomes like an input. That way other devices, like the w5100 and SD, can drive the line too, but only when that device slave select (CS) line is LOW. That is why it is important that only one SPI device is enabled at a time.
Connect CS pin to 5v, then SO pin like this:
GND --- 1K resistor --- SO pin
SO pin voltage should be 0v.
Then this:
5v --- 1K resistor --- SO pin
SO pin voltage should be 5v.
If the max is not releasing the MISO line, one of those SO voltages will not be like it should.
Hi
Sucess
I removed the board from the box where I had instaled it and all connections to it.
Then connected directly to the mega and with the code from post #63 I get
Starting SD..ok
Starting w5100..192.168.1.96
Setup complete
23.50
23.25
22.50
So here are the possibilities for the problem I was having.
-Long wires
-Some wire bronken since the cable was not new.
-Some interference from the DS18S20 sensor.
-Something else...
But now I can move foward and with trial and error find out what I was doing wrong.
Back to my early posts to use all three SPI devices together, I need to disable the other two in order to use one .
Am I right ?
To connect the max I have to use these ports or can I use any port I want ?
José
If that probe is at room temperature, that looks good. If it is at 250 degrees Celsius, then I blew it!
The reactance (combination of capacitance/inductance) of a circuit that long can cause problems with high frequency transfers.
Each SPI device requires the slave select set LOW to start a SPI transfer, and set HIGH to end it. How convenient!
Yes the prob is at room temp, next to the mega.
Looking at the code from post #63 I noticed that you disable the we 5100 after you start it, but you dont do that for the pin from the sd card. Then you start mesuring the max values. Shouldn't youu disable the sd card pin first in order to use the SPI bus for the max ?
José
Ok
Using the cable again I get bad results.
Do you think the problem is because I am using cat5 network cable ?
Could the twisted pairs explain my strange behaviours ?
Jose
jmaxado:
Yes the prob is at room temp, next to the mega.Looking at the code from post #63 I noticed that you disable the we 5100 after you start it, but you dont do that for the pin from the sd card. Then you start mesuring the max values. Shouldn't youu disable the sd card pin first in order to use the SPI bus for the max ?
You caught me! I'm a cheater!
I disable the w5100 SPI, then disable the max6675 SPI, and the only device remaining is the one I am about to initialize. I know the SD.begin() function returns with the SD SPI disabled (D4 HIGH). That means at that point, they are all disabled.
Ethernet.begin() is only function that returns with the SPI enabled (bug), so you must set D10 HIGH after that call. Now, once again, all the SPI interfaces are disabled.
Hello
I am back to testing.
I am using a cat5 cable to monitor the burning chanber.
Not just for the max6675 but also two DS18S20, one rele and one servo motor.
The cables i was using for the max were:
+5V-Green
Ground- Green and white
SCK- Orange
CS- Orange and white
SO- Blue
With this configuration the code from post #63 was not running.
Today I exchange the Blue and the Orange/White wires and I got this result
Starting SD..fail
Setup complete
14.0
13.50
14.0
So i belive the problem is the twisted wires inside the cat5 cable.
Could this be the reason ?
If i use only one wire from each twisted pair could this solv my problem ?
Jose
