FYI, in my case adding just the capacitor onto the sensor power pins (directly on the sensor, not Arduino) did not reduce the spikes in measured distance readings much. But adding a 10ohm resistor between Arduino +5V power and the capacitor improved things a lot. Here are the standard deviations of measured distance (about 10cm from sensor, measured every 7ms):
plain sensor connected to Arduino +5V/GND: 0.27cm standard deviation, mainly consisting of ca 1cm spikes occuring ca 20 times per sec
with 100uF cap on sensor power pins: 0.15cm
with 100uF cap+10ohm resistor: 0.03cm
