I have a Python script that sends data over the serial port to the Arduino. When the Arduino receives data from the serial port it seems to 'reset' and run through the setup routine again. Is this normal behavior?
Basically I am monitoring a gmail account and then sending information to my uno and displaying messages on an LCD.
This code was thrown together quickly from examples...just trying to see if I can get everything to flow correctly.
Thanks!
Matt
Arduino code
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
void setup(){
// initialize the serial communications:
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.print("XXXXXXXX Environment Status");
for (int i = 1; i < 12; i++) {
lcd.scrollDisplayLeft();
delay(300);
lcd.scrollDisplayRight();
delay(300);
delay(3000);
lcd.clear();
lcd.print("Monitoring...");
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
Python Script
import imaplib
import serial
import time
def serialSend(serMsg):
# Open a connection to the serial port.
ser = serial.Serial('COM7')
time.sleep(1.5)
# Send data over serial port
written = ser.write(serMsg)
ser.close()
return
mlSubSrch1 = "build"
mlSubSrch2 = "online"
mlSubSrch3 = "reboot"
mlSubSrch4 = "ready"
mlSubSrch5 = "Build"
server = imaplib.IMAP4_SSL('imap.gmail.com','993')
server.login('xxx@gmail.com','xxxxxx')
count = 0
while (count < 10000):
server.select('inbox')
for i in server.search(None,'all')[1][0].split():
mlSubject ="\n"+server.fetch(i,'(BODY[HEADER.FIELDS (Subject)])')[1][0][1]
found1 = mlSubject.find(mlSubSrch1)
found2 = mlSubject.find(mlSubSrch2)
found3 = mlSubject.find(mlSubSrch3)
found4 = mlSubject.find(mlSubSrch4)
found5 = mlSubject.find(mlSubSrch5)
dsEnv = mlSubject.split("is")[0]
dsEnv = dsEnv[10:]
dsEnv = dsEnv.strip()
if found1 != -1:
print dsEnv + "- Build"
serialSend(dsEnv + "-Build")
elif found2 != -1:
print dsEnv + "- Online"
serialSend(dsEnv + "-Online")
elif found3 != -1:
print dsEnv + "- Reboot"
serialSend(dsEnv + "-Reboot")
elif found4 != -1:
elif found5 != -1:
server.store(i, '+FLAGS', '\\Seen')
server.store(i, '+FLAGS', '\\Deleted')
server.expunge()
count = count + 1
print count
time.sleep(2)
