I have the "famous" problem with avrdude, on the Pro Mini, I was searching in the forum and trough internet, and I haven't found any solution, the thing is that I have a particularity, this only happens with 5V boards, 3.3V boards work perfect.
I tried with 3 boards of 5V, and none of them works.
I tried with 2 different programmers without results too.
Obviously when I change from 3.3V boards to 5V boards, I change the processor on the IDE, and change the programmer's jumper.
Any clues for what can be happening?
I write down the error message, just in case.
Greetings.
Arduino:1.6.12 (Windows 10), Tarjeta:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
El Sketch usa 928 bytes (3%) del espacio de almacenamiento de programa. El máximo es 30.720 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 2.039 bytes para las variables locales. El máximo es 2.048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf4
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf4
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
