Find below an experimental class that implements a FastShiftOut Class which is derived from the Print class.
This means that all print and println interfaces are available to FSO, including printing of strings, floats and ints.
The class does not implement the latch signal (e.g. to be used for one or more 74HC595)
The class is not tested so use at your own risk
as always comments and remarks are welcome.
FastShiftOut.h
// 聽 聽FILE: FastShiftOut.h
// 聽AUTHOR: Rob Tillaart
// VERSION: 0.1.03
// PURPOSE: shiftout that implements the Print interface
// 聽 聽 URL:
// Released to the public domain
#ifndef FastShiftOut_h
#define FastShiftOut_h
#if defined(ARDUINO) && ARDUINO >= 100
聽#include "Arduino.h"
#else
聽#include "WProgram.h"
#endif
#define FASTSHIFTOUT_LIB_VERSION "0.1.03"
#include "Print.h"
class FastShiftOut : public Print
聽public:
FastShiftOut(uint8_t, uint8_t, uint8_t);
聽 聽size_t write(uint8_t);
聽 聽int read(void);
聽private:
聽 聽uint8_t _bitorder;
聽 聽int _value;
聽 聽
uint8_t _databit;
聽 聽volatile uint8_t *_dataout;
聽 聽
uint8_t _clockbit;
聽 聽volatile uint8_t *_clockout;
#endif
// -- END OF FILE --
FastShiftOut.cpp
// 聽 聽FILE: FastShiftOut.cpp
// VERSION: 0.1.03
// 聽 聽 URL:
#include "FastShiftOut.h"
// Constructor
// prepares the digitalWrite()
FastShiftOut::FastShiftOut(uint8_t datapin, uint8_t clockpin, uint8_t bitOrder)
聽 聽_bitorder = bitOrder;
聽 聽_value = -1;
聽 聽pinMode(datapin, OUTPUT);
聽 聽pinMode(clockpin, OUTPUT);
聽 聽
聽 聽// uint8_t _datatimer 聽= digitalPinToTimer(datapin);
聽 聽// if (_datatimer != NOT_ON_TIMER) turnOffPWM(_datatimer); TODO
uint8_t _dataport 聽 = digitalPinToPort(datapin);
聽 聽_dataout = portOutputRegister(_dataport);
_databit = digitalPinToBitMask(datapin);
聽 聽
聽 聽// uint8_t _clocktimer = digitalPinToTimer(clockpin);
聽 聽// if (_clocktimer != NOT_ON_TIMER) turnOffPWM(_clocktimer);
uint8_t _clockport 聽= digitalPinToPort(clockpin);
聽 聽_clockout = portOutputRegister(_clockport);
_clockbit 聽 = digitalPinToBitMask(clockpin);
// write() must implement the virtual write of Print class
size_t FastShiftOut::write(uint8_t data)
聽 聽_value = data;
聽 聽for (uint8_t i = 0; i < 8; i++) 聽
聽 聽{
聽 聽 聽 聽uint8_t v;
聽 聽 聽 聽if (_bitorder == LSBFIRST) 聽 v = !!(_value & (1 << i));
聽 聽 聽 聽else 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽v = !!(_value & (1 << (7 - i)));
聽 聽 聽 聽
聽 聽 聽 聽uint8_t oldSREG = SREG;
聽 聽 聽 聽cli();
聽 聽 聽 聽if (v == LOW) 聽*_dataout &= ~_databit;
聽 聽 聽 聽else 聽 聽 聽 聽 聽 *_dataout |= _databit;
聽 聽 聽 聽*_clockout |= _clockbit;
聽 聽 聽 聽*_clockout &= ~_clockbit;
聽 聽 聽 聽SREG = oldSREG;
聽 聽}
聽 聽return 1;
// reads back the last value written.
int FastShiftOut::read()
聽 聽return _value;
FSO001.ino, tests some performance compared to standard shiftOut()
FastShiftOut FSO(12, 13, LSBFIRST);
聽Serial.begin(115200);
聽Serial.println("Start FSO");
聽unsigned long start = millis();
聽for (int i=0; i<10000; i++)
聽{
聽 聽FSO.write(0x55);
聽}
聽Serial.println((millis() - start)/10.0, 4);
聽start = millis();
聽{
聽 聽FSO.write(0x55);
聽 聽FSO.write(0x55);
聽}
聽start = millis();
聽{
聽 聽shiftOut(12, 13, 0x55, LSBFIRST);
聽}
聽start = millis();
聽{
聽}
聽Serial.println("test print interface");
聽start = millis();
聽{
聽 聽FSO.println("Hello world");
聽}
聽start = millis();
聽{
聽 聽FSO.println(1357);
聽}
聽start = millis();
聽{
聽 聽FSO.println(3.14159265, 4);
聽}
聽Serial.println("done");
output:
Start FSO
61.3000
122.4000
114.8000
229.5000
812.8000
403.8000
572.5000
done
The FSO Class is almost 2x faster than normal shiftOut() [times in uSec]
Times for strings, ints and floats are approx. as expected. (add newline chars too)
update:
latest version check - Arduino/libraries at master 路 RobTillaart/Arduino 路 GitHub -
