String Array (again)
Hello,
I had posted on this topic before, but it had a different tack. My problem is (simplified a teeny bit for the forum) is that I have three strings of varying length. I want to reference them in an array, so that I can reference the nth string randomly
I have defined the three strings as separate variables. Then create an array of pointers to the individual strings. Thus, when I want to use (print) a string, I can index the pointer array.
Clear as mud? I hope not. I am sure that I am doing mutiple things wrong in the code below; mainly because it won't compile. Can you take a look and explain where my misunderstanding lies?
char MoveString_0[]  ="#0P1500#1P1500#2P1000#3P570#4P1500#5P2400#6P510#8P1500#9P1500#10P1500#11P1400T1000";
char MoveString_1[]  ="#2P1100";
char MoveString_2[]  ="#0P2000 #1P1100 T100";
char* MoveCommand[] =
(&MoveString_0) ,
(&MoveString_1) ,
(&MoveString_2)
Serial.println( *MoveCommand[1] );
while (-1){};
The error I am getting is:
MoveCommandTest:17: error: cannot convert 'char (*)[83]' to 'char*' in initialization
Ditch the & :
(&MoveString_0) ,
(&MoveString_1) ,
(&MoveString_2)
Or use &MoveString_0[0];
The name of the array without the brackets IS a pointer. So with the extra & there you are trying to take the address of the pointer. OR if you put the brackets and 0 on the end and leave the & then you are taking the address of the first element in the array. It will work either way but I like it better if you just drop the &.
That compiles... Thanks! and thanks for the great explanation, too.
My Mega is being shipped and I can test this on the hardware soon.
So what's the syntax I need when printing (or referencing) the nth string?
Serial.println(moveCommand[n]); should do it. That would be the same as saying Serial.println(moveString_0);
instead of
(&MoveString_0) ,
(&MoveString_1) ,
(&MoveString_2)
you can simply write it as
  "#0P1500#1P1500#2P1000#3P570#4P1500#5P2400#6P510#8P1500#9P1500#10P1500#11P1400T1000",
  "#2P1100",
and you can access it as
Serial.println( MoveCommand[1] );
