In the interest of learning, i am trying to put another switch that works of the lcd menu with a button press with the 2 existing switches.
I copied all the entry's in the sketch of switch 1 and changed them to switch 3, inorder to make the switch state on or off for switch 3 it needs to work independently.
I have narrowed the code down to the section (bool StorageClass::readS3State(int patchno))
the section with the bit_fld toggles the on and off( i think). But i dont know what the (return (EEPROM.read(Offset(patchno) + 3) & 0x1) == 0x1) is and how it works.
Would someone be kind enough to explain this, and what the new entry's for the switch should be.
i have tried changing the entry's to see how they work.but cant get it working.
// Memory stucture:
// byte 0 -> init marker
// byte 1 -> midi channel
// byte 2 -> maximum bank
// byte 4/5 -> PDL1 min
// byte 6/7 -> PDL1 max
// byte 8/9 -> PDL2 min
// byte 10/11 -> PDL2 max
// byte 12 -> Performance mode
// from byte 16 and further
// Each patch, 16 bytes long:
// 0 : ProgChangeNo
// 1 : S1 CC
// 2 : S2 CC
// 3 : S1/S2 state and vol->wah (bitwise)
// 4..15: 12-character name
// 16 : S3 CC
// 17 : S3 State
#include "Storage.h"
#include "constants.h"
void StorageClass::init()
if (EEPROM.read(0) != 127)
EEPROM.write(0,127);
// for (int i = 0; i < 4024; i++)
// EEPROM.write(i, 0);
writeChannel(1);
writeMaxBank(12);
writePatchName(0, "JMP1");
writePatchName(1, "CleanChorus");
writePatchName(2, "Clean");
writePatchName(3, "Lead");
writePatchName(4, "JMP1");
writePatchName(5, "CleanCh");
writePatchName(6, "Cry");
writePatchName(7, "Luke");
writePatchName(8, "JMP1!");
writePatchName(9, "Clubclean");
writePatchName(10, "Country");
writePatchName(11, "CountryTS");
for (int i = 0; i < 63; i++)
writeS1CC(i, 50);
writeS2CC(i, 17);
writeS3CC(i, 90);
for (int i = 0; i < 4; i++)
writeS1State(i, true);
writeS2W2VState(6, true);
writeS3State(2, true);
int StorageClass::Offset(int patchno)
return (patchno * 16) + 16;
byte StorageClass::readChannel()
EEPROM.read(1);
void StorageClass::writeChannel(byte channel)
EEPROM.write(1, channel);
byte StorageClass::readMaxBank()
EEPROM.read(2);
void StorageClass::writeMaxBank(byte maxbank)
// 63 programs max
maxbank = min(byte(63 / banksize), maxbank);
EEPROM.write(2, maxbank);
String StorageClass::readPatchName(int patchno)
// start in EEPROM from position 16, max = 1007 => 63 patches max!
// 0 : ProgChangeNo (not used)
// 1 : S1 CC
// 2 : S2 CC
char buf[13];
for (int i = 0; i < 12; i++)
buf[i] = EEPROM.read(Offset(patchno) + i + 4);
buf[12] = 0;
return String(buf);
void StorageClass::writePatchName(int patchno, char *patchname)
int len = strlen(patchname);
if (i < len)
EEPROM.write(Offset(patchno) + i + 4, patchname[i]);
EEPROM.write(Offset(patchno) + i + 4, ' ');
byte StorageClass::readS1CC(int patchno)
return EEPROM.read(Offset(patchno) + 1);
void StorageClass::writeS1CC(int patchno, byte CC)
EEPROM.write(Offset(patchno) + 1, CC);
byte StorageClass::readS2CC(int patchno)
return EEPROM.read(Offset(patchno) + 2);
void StorageClass::writeS2CC(int patchno, byte CC)
EEPROM.write(Offset(patchno) + 2, CC);
byte StorageClass::readS3CC(int patchno)
return EEPROM.read(Offset(patchno) + 3);
void StorageClass::writeS3CC(int patchno, byte CC)
EEPROM.write(Offset(patchno) + 3, CC);
bool StorageClass::readS1State(int patchno)
return (EEPROM.read(Offset(patchno) + 3) & 0x1) == 0x1;
void StorageClass::writeS1State(int patchno, bool state)
byte bit_fld = EEPROM.read(Offset(patchno) + 3);
if (state)
bit_fld |= 1 << 0;
bit_fld &= ~(1 << 0);
EEPROM.write(Offset(patchno) + 3, bit_fld);
bool StorageClass::readS2State(int patchno)
return (EEPROM.read(Offset(patchno) + 3) & 0x2) == 0x2;
void StorageClass::writeS2State(int patchno, bool state)
if (state)
bit_fld |= 1 << 1;
bit_fld &= ~(1 << 1);
bool StorageClass::readS2W2VState(int patchno)
return (EEPROM.read(Offset(patchno) + 3) & 0x4) == 0x4;
void StorageClass::writeS2W2VState(int patchno, bool state)
if (state)
bit_fld |= 1 << 2;
bit_fld &= ~(1 << 2);
void StorageClass::writePDL1Min(int Value)
EEPROM.write(4,highByte(Value));
EEPROM.write(5,lowByte(Value));
int StorageClass::readPDL1Min()
return word(EEPROM.read(4),EEPROM.read(5));
void StorageClass::writePDL1Max(int Value)
EEPROM.write(6,highByte(Value));
EEPROM.write(7,lowByte(Value));
int StorageClass::readPDL1Max()
return word(EEPROM.read(6),EEPROM.read(7));
void StorageClass::writePDL2Min(int Value)
EEPROM.write(8,highByte(Value));
EEPROM.write(9,lowByte(Value));
int StorageClass::readPDL2Min()
return word(EEPROM.read(8),EEPROM.read(9));
void StorageClass::writePDL2Max(int Value)
EEPROM.write(10,highByte(Value));
EEPROM.write(11,lowByte(Value));
int StorageClass::readPDL2Max()
return word(EEPROM.read(10),EEPROM.read(11));
byte StorageClass::readPrgChg(int patchno)
// 1 : S1 CC
// 2 : S2 CC
return EEPROM.read(Offset(patchno));
void StorageClass::writePrgChg(int patchno, byte PrgChg)
EEPROM.write(Offset(patchno), PrgChg);
void StorageClass::ResetProgramMap()
for(int i = 0; i < 63; i++)
writePrgChg(i, i);
void StorageClass::writePerfMode(boolean Value)
EEPROM.write(12,Value ? 1 : 0);
boolean StorageClass::readPerfMode()
return EEPROM.read(12) == 1;
void StorageClass::writeS3State(int patchno, bool state)
if (state)
bit_fld |= 1 << 0;
