I am struggeling using CAMPA and COMPB correctly. I would like to start an action by an external interrupt on PIN2 (UNO) and start Timer1. After TIMER1 has started it shall use COMPA and COMPB to start certain actions, but NOT resetting the TIMER1. That reset shall happen later on special command at a later point in time. The script should enable and disable the LED13 on the UNO board. Here is the code I tried to start with COMPA and COMPB, but the LED won't go off...
// avr-libc library includes
#include <avr/io.h>
#include <avr/interrupt.h>
#define LEDPIN 13
int timer;
Â
 pinMode(LEDPIN, OUTPUT);
 cli();          // disable global interrupts
 pinMode(2, INPUT);    // Enable Pin2 as input to interrupt
 EIMSK |= (1 << INT0);  // Enable external interrupt INT0 (see table 13-2-2 in Atmel 328 spec)
 EICRA |= (1 << ISC01);  // Trigger INT0 on rising edge (see table 13-1 in Atmel 328 spec)
 EICRA |= (1 << ISC00);  // Trigger INT0 on riding edge (see table 13-1 in Atmel 328 spec)
 // initialize Timer1
 // ZERO Timer1
 TCCR1A = 0;       // set entire TCCR1A register to 0
 TCCR1B = 0;       // same for TCCR1B
 // set compare match register to desired timer count:
 OCR1A = 15624;      // turn on CTC mode:initial value changed in loop
 OCR1B = 30000;      // turn on CTC mode:initial value changed in loop
 TCCR1B |= (1 << WGM12); // Set CS10 and CS12 bits for 1024 prescaler:
 TCCR1B |= (1 << CS10);  // prescaler 1024
 TCCR1B |= (1 << CS12);  // prescaler 1024
 TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt:
 TIMSK1 |= (1 << OCIE1B); // enable timer compare interrupt:
 sei();          // Enable global interrupts
ISR(TIMER1_COMPA_vect){digitalWrite(LEDPIN, HIGH);}
ISR(TIMER1_COMPB_vect){digitalWrite(LEDPIN, LOW);}
You are also setting the Waveform Generator Mode to 4 (only WGM12 set) which resets the timer to 0 when it reaches the value in OCR1A. You will never reach the value in OCR1B so that interrupt will never occur. You probably want Mode 0 where the timer counts up to FFFF and then re-starts at 0. After you reset the timer the LED should come on about a second later and stay on for 0.92 seconds. The who cycle will then repeat every about every 4.2 seconds.
Hi johnwasser,
I improved my sketch and the compA and compB are working. I let the LED on pin13 switch on (compA) and off (compB) which works well.
What is missing/ not working is:
External interrupt on INT0 on rising flag
this interrupt starts the timer1 starting at zero
stopping the timer1 with compB
Is that possible?
#include <avr/io.h>
#define LEDPIN 13
// int timer;
// unsigned int counter;
 EICRA |= (1 << ISC00);  // Trigger INT0 on rising edge (see table 13-1 and 13-2 in Atmel 328 spec)
 EICRA |= (1 << ISC01);  // Trigger INT0 on rising edge (see table 13-1 and 13-2 in Atmel 328 spec)
 OCR1A = 100;      // COMPA
 OCR1B = 50000;     // COMPB
 TCCR1B = 0;       // set entire TCCR1B register to 0
 TCCR1B |= (1 << CS12);  // prescaler 256- see table 16-5
//***Not shiure if this is right...
 TCCR1A |= (1 << COM1B0);  // Set OC1A/OC1B on Compare Match (Set output to high level).- see table 16-1
 TCCR1A |= (0 << COM1B1);  // Set OC1A/OC1B on Compare Match (Set output to high level).- see table 16-1
Â
 TIMSK1 |= (1 << OCIE1B); // enable timer compare interrupt channel B:
 TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt channel A:
 attachInterrupt(0, start, RISING);
ISR(EXT_INT0_vect){Â Â
//Reset Timer1
TCCR1A = 0;Â Â Â Â Â Â Â // set entire TCCR1A register to 0
TCCR1B = 0;Â Â Â Â Â Â Â // same for TCCR1B and setting timer1 to 0
void start()
//want to start the timer here
//TCNT1H=0; //To do a 16-bit write, the high byte must be written before the low byte
//TCNT1L=0; //To do a 16-bit write, the high byte must be written before the low byte
 Serial.println("NUN");
// digitalWrite(LEDPIN, !digitalRead(LEDPIN));
Serial.println("AHA");
//want to stop the timer here
It looks to me like you are starting the timer in setup() and then calling start() which does nothing. The code in the ISR looks like it stops the timer by setting the control registers to 0.
Perhaps you should move the code that starts the timer into start() and call it from your external interrupt instead of from setup().
Then you can take the code the stops the timer, put it in a function called stop() and call it from the COMPB interrupt to stop the timer.
the "attachInterrupt(0, start, RISING);" was a try to get the external interrupt running because I couldn't make it with real "C" . And the ISR(EXT_INT0_vect) function is basically the double cover to the attachInterrupt...but both doesn't work... :~
I wanted to put the counter at least to zero. I again read the datasheet and should have put a zero value to the TCNT1 register and not to TCCR1* control register , right?
I did not know that I started the timer...I thought it would be running anyhow. How can I start and stop it?
Yes.
soulid:
The timer starts when you set the Clock Select Bits in TCCR1B to something other than 0.
changed the code as proposed. There is "a" reaction to what I have written, but not as expected. The (red) Interrupt rising line is not very close to the (blue) trigger HIGH expected 20 ticks after. Changing the CompB from 100 to 10.000 (which is intended to increase pulseduration but keeping the rising edge at the same position) changes the rising edge position.
Here is the code and a oscilloscope screenshot (blue line is trigger and red line is interrupt reaction- time/ dev= 50mS):
#include <avr/io.h>
#define LEDPIN 13
void setup(){Â
//Â TCCR1A = 0;Â Â Â Â Â Â Â // set entire TCCR1A register to 0
 TCCR1A = B11110000;   //see table 16-1
void loop(){
OCR1A = 20;Â Â Â Â Â Â // COMPA
OCR1B = 40;Â Â Â Â Â // COMPB
void start(){
 //want to start/ restart the timer here
 TCCR1B |= (1 << CS10);  // prescaler 1- see table 16-5 and (re)start timer1
 TCCR1B = 0; //stop timer here
100-20=80 80/16=5 microseconds. at 0.5 milliseconds (500 microseconds) per division the pulse would be about 1/100th of a division.
10000-20 = 9980. 9980/16=623 microseconds or a little over 1 division.
I suspect the long delay before triggering is a wrap-around of the timer. Try resetting more of the registers:
#include <avr/io.h>
#define LEDPIN 13
void setup(){Â
 TCCR1A = 0;       // Clear TCCR1A
 TCCR1B = 0;       // Clear TCCR1B
 TCCR1C = 0;       // Clear TCCR1C
 TCNT1 = 0;        // Clear the timer
 TIMSK1 = 0;       // Clear the interrupt mask
Â
 TCCR1A = B11110000;   // Set OC1A/OC1B on Compare Match, clear OC1A/OC1B at BOTTOM
 OCR1A = 20;       // COMPA at 20/16ths microseconds
 OCR1B = 40;       // COMPB at 40/16th microseconds
void loop(){
void start(){
 TCCR1B |= (1 << CS10);  // prescaler=1 16 MHz clock
I tried several values and found a "base delay" of abput 12.5us meaning that there is no Interupt control below that. From that value on the control works , but I can live with that.
Thank you for your brilliant help!
The digitalWrite() function takes a while and probably explains much of your 12.5 microsecond delay. You can get faster response using direct port access. On the UNO, Pin 13 is PORTB bit 5. (See: Arduino Pins - Google Drive )
Opening a very old subject I got solved with the great help of johnwasser.
After having COMPA and COMPB running well on Arduino UNO, I want to transfer this behavior to Arduino MEGA. :
Input interrupt pin is PIN2 (so timer 3, right?)
Output is PIN6 and 13
I am reading the 2560 datasheet but I am failing somewhere
In "start" interrupt, the timer TCNT3 is cleared and by setting the prescaler TCCR3B CS30 to "1" and to 16MHz, the timer3 is starting.
When meeting COMPA value the LEDs is intendet to be switched ON and with COMPB the LEDs shall switch OFF again.
The code works so far that it starts the "start()" section, but the COMPA and COMPB does not work.
Any idea why not?
//For Arduino Mega2560
#include <avr/io.h>
#define LEDPIN 13
#define LEDPIN1 6
//*********************************PIN für den Pickup*********************
const byte interruptPin = 2;
//**************************KALIBRIERTABELLE***************************************
 Serial.begin(57600);// start serial for output. Make sure you set your Serial Monitor to the same!
 pinMode(LEDPIN1, OUTPUT);
 TCCR3A = 0;       // Clear TCCR1A
 TCCR3B = 0;       // Clear TCCR1B
 TCCR3C = 0;       // Clear TCCR1C
 TCNT3 = 0;        // Clear the timer
 TIMSK3 = 0;       // Clear the interrupt mask
 TIMSK3 |= (1 << OCIE1A); // enable timer compare interrupt channel A:
 TIMSK3 |= (1 << OCIE1B); // enable timer compare interrupt channel B:
 TCCR3A = B11110000;   // Set OC1A/OC1B on Compare Match, clear OC1A/OC1B at BOTTOM
 OCR3A = 20;       // COMPA at 20/16ths microseconds
 OCR3B = 50;       // COMPB at 40/16th microseconds
 pinMode(interruptPin, INPUT_PULLUP);
 attachInterrupt(0, start, CHANGE);
 Â
void start() {
 TCCR3B |= (1 << CS30);  // prescaler=1 16 MHz clock
//digitalWrite(LEDPIN1, HIGH);
ISR(TIMER1_COMPA_vect) {
ISR(TIMER1_COMPB_vect) {
 digitalWrite(LEDPIN1, LOW);
 TCCR3B = 0; //stop timer here
Needed another 6 hrs to get this running. But here it is- the Mega answers the trigger with about +/- 2-4ys
Here is the code:
#include <avr/io.h>
#define LEDPIN 13
#define LEDPIN1 6
int ledState = LOW;Â Â Â Â Â Â // ledState used to set the LED
int ledState1 = LOW;Â Â Â Â Â Â // ledState used to set the LED
 TIMSK3 |= (1 << OCIE3A); // enable timer compare interrupt channel A:
 TIMSK3 |= (1 << OCIE3B); // enable timer compare interrupt channel B:
Â
 OCR3A = 6;       // COMPA
 OCR3B = 15;       // COMPB
 attachInterrupt(0, start, FALLING);
void start() {
 TCCR3B |= (1 << CS31)|(1 << CS30);  // prescaler=64
 TCCR3B |= (1 << WGM33)|(1 << WGM32);  // Enable CTC
ISR(TIMER3_COMPA_vect) {
 PORTH = 0b00001000;
ISR(TIMER3_COMPB_vect) {
 PORTH = 0b00000000;
