Following ryoru feedback available at How to Controll Nuvoton ISD1760 Chip? - Libraries - Arduino Forum, I am posting a new version of the library:
ISD1700.h
ISD1700.h - Library for Nuvoton ISD1700 chipcorders
Copyright (c) 2009 Marcelo Shiniti Uchimura.
Author: Marcelo Shiniti Uchimura, CITS, <www.cits.br>
Version: Jan 20, 2016
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef ISD1700_h
#define ISD1700_h
#define SCK_PIN 13
#define MISO_PIN 12
#define MOSI_PIN 11
#include "Arduino.h"
class ISD1700
private:
uint8_t _SSPin; // Arduino's digital pin which chipcorder is attached to
/* status registers */
uint16_t _SR0; // Status Register #0 uint16_t <15:0>
uint8_t _SR1; // Status Register #1 uint8_t <7:0>
uint16_t _APC; // Analog Path Configuration Register uint16_t <11:0>
uint16_t _PP; // Playback Pointer uint16_t <10:0>
uint16_t _RP; // Record Pointer uint16_t <10:0>
uint8_t _DEVICEID; // Device Identification Register uint8_t <7:3>
/* private methods */
uint8_t spi_transfer(uint8_t);
void sendCmd(uint8_t);
void sendCmd(uint8_t, uint16_t);
void sendCmd(uint8_t, uint16_t, uint16_t);
public:
/* constructor */
ISD1700(uint8_t);
/* functions to enquire status */
uint8_t RDY(void);
uint8_t ERASE(void);
uint8_t PLAY(void);
uint8_t REC(void);
uint8_t SE1(void);
uint8_t SE2(void);
uint8_t SE3(void);
uint8_t SE4(void);
uint8_t CMD_ERR(void);
uint8_t FULL(void);
uint8_t PU(void);
uint8_t EOM(void);
uint8_t INT(void);
/* chipcorder commands */
void pu(void);
void stop(void);
void reset(void);
void clr_int(void);
uint8_t rd_status(void);
uint16_t rd_play_ptr(void);
void pd(void);
uint16_t rd_rec_ptr(void);
uint8_t devid(void);
void play(void);
void rec(void);
void erase(void);
void g_erase(void);
uint16_t rd_apc(void);
void wr_apc1(uint16_t);
void wr_nvcfg(void);
void ld_nvcfg(void);
void fwd(void);
void chk_mem(void);
void extclk(void);
void wr_apc2(uint16_t);
void set_play(uint16_t, uint16_t);
void set_rec(uint16_t, uint16_t);
void set_erase(uint16_t, uint16_t);
#endif
