Topic: SD card destroyed (Read 1 time) previous topic - next topic
Aug 07, 2017, 02:16 am Last Edit: Aug 07, 2017, 02:16 am by jremington
Electrical systems in cars are extremely noisy and can destroy unprotected electronics.
Post a wiring diagram.
In part 1 of your code there is an extra }. Delete the } at the end of that file.
If you are using a NANO or UNO or similar, I suspect that your use of the String class is causing the problem.
Change all uses of the String class to C strings and it should solve the problem.
i'll be more thankful if you send a link about the  C strings or an example
and how does a ram problem destroy the SD card hardware that it become unformattable
What kind of cardreader do you use with the Arduino?
SD cards are 3.3V; using 5V power and signals can damage it after a while.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Thank you all for your answers
i think a very helping site is :>
