The four inputs A0 to A3 define the number you will display.
~LT is the lamp test and should be wired high for normal operation.
The ripple blanking input depends on how you intend to wire them up. Are you going to multiplex the display or are the displays going to be on all the time?
But basically it allows leading zero suppression in multi digit displays, if that is what you want.
