Topic: SER2NET Control pins (Read 325 times) previous topic - next topic
mateusguilherme
Is it possible to control arduino yun shield digital pins with ser2net?
e.g with putty -> telnet 192.168.1.104:7000 - write message "led13 on"
thanks
ballscrewbob
If there is a "firmata" or similar for the YUN then yes.
Not tried or looked for it on the YUN but I do know there are a few variations for some of the other boards.
I do believe there is also an example of doing something similar to what you want in the YUN example sketches  too.
You can also shell into the YUN from the linux side to do similar.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
mateusguilherme
Thanks
Solutions install  Ser2net  opkg install ser2net -> enable mode port:raw and serial 57600 baunds /etc/ser2net -> put arduino yun shield in mode "control" and 57600 baund.
use put mode raw ip:port
