Topic: administraion web i/f files disappear from yun file system (Read 436 times) previous topic - next topic
paolo_s46
hi everybody
I have a Yun (doghunter) configured and working fine with its application, arduino and python.
I changed the local wifi and therefore started to re-configure the board for the new SSID. A simple operation that I have done a lot of times without any problem.
Strangely now I have the following error
Code: [Select]
/usr/lib/lua/luci/dispatcher.lua:448: Failed to execute call dispatcher target for entry '/webpanel/homepage'.
The called action terminated with an exception:
/usr/lib/lua/luci/template.lua:81: Failed to load template 'linino/homepage'.
Error while parsing template '/usr/lib/lua/luci/view/linino/homepage.htm':
No such file or directory
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:448: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:195: in function </usr/lib/lua/luci/dispatcher.lua:194>
If I run an ssh from the Ethernet connection I can see that really a number of files are missing comparing to other Yun boards.
Has anybody a suggestion on how to recover, without resetting to factory default ??? (but should this operation actually solve my problem ???)
My system works with the file system extension on an SD card.
Thanks for any help
