mowcius:
I'd be interested to have a look at what you wrote for the scrolling text function - got a couple of ideas that I'd like to try with the scroll bar.
mowcius, here they are:
- The function that renders "long message", so displaying (including scroll bar) is done here:
void long_msg_lcd(phi_prompt_struct* para)
byte columns=para->step.i/100, rows=para->step.i%100, ch;
if (para->low.i>=strlen(para->ptr.msg)) ch=0;
else ch=para->ptr.msg[para->low.i];
for (byte i=0;i<rows;i++)
lcd->setCursor(para->col,para->row+i);
for (byte j=0;j<columns;j++)
if (ch==0) lcd->write(' ');
lcd->write(ch);
ch=para->ptr.msg[para->low.i+i*columns+j+1];
if (para->option==1)
byte location=int((((float)para->low.i)/strlen(para->ptr.msg)*(rows*2-2)));
lcd->setCursor(para->col+columns,para->row+i);
if (i==0)
if (location==0) lcd->write(0);
else lcd->write(1);
else if (i==rows-1)
if (location==(rows*2-2-1)) lcd->write(5);
else lcd->write(4);
else if ((location+1)/2==i)
if ((location-1)/2*2==location-1) lcd->write(2);
else lcd->write(3);
else lcd->write(' ');
- This function interacts with the user (via keypad call wait_on_escape and lcd via the long_message function) so scrolling is done here:
The reason I called this function text area is to correspond to Java's text area to display text.
int text_area(phi_prompt_struct *para)
long_msg_lcd(para);
while(true)
byte temp1=wait_on_escape(50);
switch (temp1)
case 1:
if (para->low.i+columns<para->high.i)
para->low.i+=columns;
long_msg_lcd(para);
break;
case 2:
if (para->low.i-columns>=0)
para->low.i-=columns;
long_msg_lcd(para);
break;
case 3: // Left is pressed
return(-3);
break;
case 4: // Right is pressed
return(-4);
break;
case 5: // Enter is pressed
return(1);
break;
case 6: // Escape is pressed
return (-1);
break;
default:
break;
- Here's the struct in case you need it to understand the code:
It tells you what each field holds besides comments inline with the code.
union buffer_pointer
int *i_buffer;
float * f_buffer;
char ** list;
char* msg;
union four_bytes
int i;
long l;
float f;
byte b;
char c;
struct phi_prompt_struct
buffer_pointer ptr;
four_bytes low; // Lower limit for text panel (.c), integers (.i) and floats (.f) and default item for list (.i)
four_bytes high; // Upper limit for text panel (.c), integers (.i) and floats (.f) and last item for list (.i)
four_bytes step;// Step size for integers (.i) and integer/decimal for floats (.i), such as 302 means 3 digits before decimal and 2 digits after.
byte col; // Which column to display input
byte row; // Which row to display input
byte width; // Maximal number of character on integers, floats, a list item, and total allowed input characters for text panel
int option; // What display options to choose
// LiquidCrystal *lcd; // Which display to use. Removed in second release
// phi_buttons **btns; // Which series of buttons to use. Removed in second release
void (*update_function)(phi_prompt_struct *); // This is not being used in this version but reserved for future releases.
}; //22 bytes
