Can somebody help me with the code below please?
It's a small program to control a hydrolic cilinder to operate it in and out.
1 Potmeter i use for the time/distance out,if the time/distance is reached it goes back in.
1 Potmeter for giving waitingtime to do the next cycle and so on.
I have done allot of reading forum's and projects to find out what i want.
Maybe its too difficult for a arduino starter like me......
The code below works but, what i want to do is put somekind of securety in with use of a proximity switch.
Like a reference too "see" when the cilinder is in.
Here the code
Regards everybody
int potPin1 = A0; // select pin liftheight potmeter
int potPin2 = A1; // select pin wait potmeter
int potValue1 = 0; // variable
int relaisPin = 12; // select pin relais 12
// int proxpin =10; // select pin for proximity sensor NEW
// int startbutton = 9; // select pin to startup NEW
pinMode(relaisPin, OUTPUT); // declare relaispin OUTPUT
pinMode(potPin1, INPUT); // declare 1 potmeter INPUT
pinMode(potPin2, INPUT); // declare 2 potmeter INPUT
// pinMode(proxpin, INPUT); //declare proxpin input NEW
// pinmode(startbutton, INPUT); //declare startbutton NEW
potValue1 = analogRead(potPin1); //
digitalWrite(relaisPin, HIGH); //
delay(potValue1+50); //
digitalWrite(relaisPin, LOW); //
potValue1 = analogRead(potPin2); //
delay(potValue1+150); //
Moderator edit: Real tags added
Moderator edit: Title made more meaningful (Nick Gammon)
Is the potentiometer defining time or distance? Time and distance and not the same thing.
And the problem is?
What is going to trigger the proximity switch? What is supposed to happen when that proximity switch is triggered?
For safety, these:
have got to go. You won't be able to read the proximity switch while the doNothingButHandleInterruptsForAWhile() call is happening.
It is the blink without delay example were i started with.
What i want with the prox switch is give a reference when the cilinder is in for the wait time potmeter to delay the next cycle.
I ám not sure if i must use a startbutton to startup the whole program.
I suggest starting a simple sketch that uses the proximity switch to control an LED, then combining the proximity switch logic with what you have working.
A while ago I saw an Arduino sketch that uses Hall-effect sensors to control a pair of hydraulic rams in a compressed earth brick-making machine. The link I saved is CEB Press/Research Development/Controller Design - Open Source Ecology and you should be able to navigate from there to the source code. It may be helpful to see how someone else did that job successfully.
The potmeter is defining time.
And the problem is?
For safety, these:
What i want is simple for me to discribe but very difficult to program.
I will control 1 hydraulic cilinder to go out and in.
1 potmeter i would use to control the time for steering the cilinder out.
afther this function the cilinder goes back in.
From that point when the cilinder is in, i will use the second potmeter for the delay/waiting time for the next cycle. And so on.
So far it works fine with the base program.
But i want to build in a i kind of securety with the proximity switch to know that the cilinder is in.
Afther that point de delay/wait potmeter has to do his work and start the cycle again.
And that's for me difficult to programm...
•relay-controlled electric hydraulic pump
•relay-controlled hydraulic valve to control extend/retract
•double-acting hydraulic cylinder
•limit switches at both ends of cylinder travel
First thanks for thinking with me!
The hydaulic pump pumps all the time.
So i don't need a relay to activate the pump this is regulated besides the arduino.
I only need the relay to activate the cilinder.
The cilinder goes automatical back in, because the cilinder is hanging vertical and lifts a weight that retracts the cilinder.
The reason that i need a proxswitch is to avoid dammage in the hydraulics.
The fuction of the proxswitch is to indicate that the cilinder is out/weight is down
from that point i will adjust the second potmeter for giving the time that the cilinder stays down just for some milliseconds.
the machine i will use for hammering steel sheetplates.
