Hallo,
I had some problems with this display incl. sainsmart TFT-LCD-Mega Sheeld
I had uploaded the demo-programm "TFT3_2_Mega.pde" of the documentation from the saismart-site.
After that the display worked, it cleard the display and then I could write on it by touching on it.
But now I can't upload any other programm to the board.
The Arduino-IDE give me the message: (after several minutes)
avrdude: stk500v2_ReceiverMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
The RX LED lights up short in regular intervals.
When I reset the board the programm will start and the dispaly is working.
But I can't upload any other programm.
Here the code
#define LCD_RS 38
#define LCD_WR 39
#define LCD_CS 40
#define LCD_REST 41
#define DCLK 6
#define CS 5
#define DIN 4
#define DOUT 3
#define IRQ 2
unsigned int TP_X,TP_Y;
void spistar() //SPI Start
digitalWrite(CS,HIGH);
digitalWrite(DCLK,HIGH);
digitalWrite(DIN,HIGH);
void WriteCharTo7843(unsigned char num) //SPI Write Data
unsigned char count=0;
unsigned char temp;
unsigned nop;
temp=num;
digitalWrite(DCLK,LOW);
for(count=0;count<8;count++)
if(temp&0x80)
digitalWrite(DIN,LOW);
temp=temp<<1;
nop++;
nop++;
nop++;
nop++;
unsigned int ReadFromCharFrom7843() //SPI Read Data
unsigned nop;
unsigned int Num=0;
for(count=0;count<12;count++)
Num<<=1;
digitalWrite(DCLK,HIGH);//DCLK=1; _nop_();_nop_();_nop_();
nop++;
digitalWrite(DCLK,LOW);//DCLK=0; _nop_();_nop_();_nop_();
nop++;
if(digitalRead(DOUT)) Num++;
return(Num);
void AD7843(void)
digitalWrite(CS,LOW);
WriteCharTo7843(0x90);
TP_Y=ReadFromCharFrom7843();
WriteCharTo7843(0xD0);
TP_X=ReadFromCharFrom7843();
void Lcd_Writ_Bus(char VH,char VL)
unsigned char i,temp,data;
data=VH;
for(i=22;i<=29;i++)
temp=(data&0x01);
if(temp)
digitalWrite(i,HIGH);
digitalWrite(i,LOW);
data=data>>1;
data=VL;
for(i=37;i>=30;i--)
temp=(data&0x01);
if(temp)
data=data>>1;
digitalWrite(LCD_WR,LOW);
digitalWrite(LCD_WR,HIGH);
void Lcd_Write_Com(char VH,char VL)
digitalWrite(LCD_RS,LOW);
Lcd_Writ_Bus(VH,VL);
void Lcd_Write_Data(char VH,char VL)
digitalWrite(LCD_RS,HIGH);
void Lcd_Write_Com_Data(int com,int dat)
Lcd_Write_Com(com>>8,com);
Lcd_Write_Data(dat>>8,dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
Lcd_Write_Com_Data(0x0044,(x2<<8)+x1);
Lcd_Write_Com_Data(0x0045,y1);
Lcd_Write_Com_Data(0x0046,y2);
Lcd_Write_Com_Data(0x004e,x1);
Lcd_Write_Com_Data(0x004f,y1);
Lcd_Write_Com(0x00,0x22);
void Lcd_Init(void)
digitalWrite(LCD_REST,HIGH);
delay(5);
digitalWrite(LCD_REST,LOW);
delay(15);
delay(15);
Lcd_Write_Com_Data(0x0000,0x0001); delay(1); //????
Lcd_Write_Com_Data(0x0003,0xA8A4); delay(1); //0xA8A4
Lcd_Write_Com_Data(0x000C,0x0000); delay(1);
Lcd_Write_Com_Data(0x000D,0x080C); delay(1);
Lcd_Write_Com_Data(0x000E,0x2B00); delay(1);
Lcd_Write_Com_Data(0x001E,0x00B7); delay(1);
Lcd_Write_Com_Data(0x0001,0x2B3F); delay(1); //??????320*240 0x6B3F
Lcd_Write_Com_Data(0x0002,0x0600); delay(1);
Lcd_Write_Com_Data(0x0010,0x0000); delay(1);
Lcd_Write_Com_Data(0x0011,0x6070); delay(1); //0x4030 //?????? 16??
Lcd_Write_Com_Data(0x0005,0x0000); delay(1);
Lcd_Write_Com_Data(0x0006,0x0000); delay(1);
Lcd_Write_Com_Data(0x0016,0xEF1C); delay(1);
Lcd_Write_Com_Data(0x0017,0x0003); delay(1);
Lcd_Write_Com_Data(0x0007,0x0233); delay(1); //0x0233
Lcd_Write_Com_Data(0x000B,0x0000); delay(1);
Lcd_Write_Com_Data(0x000F,0x0000); delay(1); //??????
Lcd_Write_Com_Data(0x0041,0x0000); delay(1);
Lcd_Write_Com_Data(0x0042,0x0000); delay(1);
Lcd_Write_Com_Data(0x0048,0x0000); delay(1);
Lcd_Write_Com_Data(0x0049,0x013F); delay(1);
Lcd_Write_Com_Data(0x004A,0x0000); delay(1);
Lcd_Write_Com_Data(0x004B,0x0000); delay(1);
Lcd_Write_Com_Data(0x0044,0xEF00); delay(1);
Lcd_Write_Com_Data(0x0045,0x0000); delay(1);
Lcd_Write_Com_Data(0x0046,0x013F); delay(1);
Lcd_Write_Com_Data(0x0030,0x0707); delay(1);
Lcd_Write_Com_Data(0x0031,0x0204); delay(1);
Lcd_Write_Com_Data(0x0032,0x0204); delay(1);
Lcd_Write_Com_Data(0x0033,0x0502); delay(1);
Lcd_Write_Com_Data(0x0034,0x0507); delay(1);
Lcd_Write_Com_Data(0x0035,0x0204); delay(1);
Lcd_Write_Com_Data(0x0036,0x0204); delay(1);
Lcd_Write_Com_Data(0x0037,0x0502); delay(1);
Lcd_Write_Com_Data(0x003A,0x0302); delay(1);
Lcd_Write_Com_Data(0x003B,0x0302); delay(1);
Lcd_Write_Com_Data(0x0023,0x0000); delay(1);
Lcd_Write_Com_Data(0x0024,0x0000); delay(1);
Lcd_Write_Com_Data(0x0025,0x8000); delay(1);
Lcd_Write_Com_Data(0x004f,0); //???0
Lcd_Write_Com_Data(0x004e,0); //???0
void Pant(char VH,char VL)
int i,j;
digitalWrite(LCD_CS,LOW);
Address_set(0,0,239,319);
for(i=0;i<320;i++)
for (j=0;j<240;j++)
Lcd_Write_Data(VH,VL);
digitalWrite(LCD_CS,HIGH);
for(int p=22;p<42;p++)
pinMode(p,OUTPUT);
for(int p=2; p<7;p++)
pinMode(p,OUTPUT);
pinMode(DOUT,INPUT);
pinMode(IRQ,INPUT);
Lcd_Init();
Pant(0x00,0xff);
Pant(0xff, 0xff);
unsigned char flag;
unsigned char ss[6];
unsigned int lx,ly;
spistar();
while(1)
flag = digitalRead(IRQ);
if (flag == 0)
AD7843();
lx=((TP_X-340)*10/144);
//if(lx>237) lx=237;
ly=320-((TP_Y-320)/11);
//if(ly<0) ly=0;
Address_set(lx,ly,lx+2,ly+2);
Lcd_Write_Data(0,255);
Loop back test descriped her in the forum worked.
How can I solve the problem?
Thanks in advance.
E_T
