code for display numbers atseven segment display using 4x4 keypad, decoder 7447
hi I am new in arduino too, and i want to display numbers 0 to 9, in a 7-segment display using keypads (4x4) and arduino, please let me know if somebody can help me thank you.
What help do you need?
SIMPLE CODE THAT MIGHT ANSWER YOUR QUESTION
byte seven_seg_digits[10][7] = { { 1,1,1,1,1,1,0 },  // = 0
                                                           { 0,1,1,0,0,0,0 },  // = 1
                                                           { 1,1,0,1,1,0,1 },  // = 2
                                                           { 1,1,1,1,0,0,1 },  // = 3
                                                           { 0,1,1,0,0,1,1 },  // = 4
                                                           { 1,0,1,1,0,1,1 },  // = 5
                                                           { 1,0,1,1,1,1,1 },  // = 6
                                                           { 1,1,1,0,0,0,0 },  // = 7
                                                           { 1,1,1,1,1,1,1 },  // = 8
                                                           { 1,1,1,0,0,1,1 }   // = 9
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  writeDot(0);  // start with the "dot" off
void writeDot(byte dot) {
  digitalWrite(9, dot);
void sevenSegWrite(byte digit) {
  byte pin = 2;
  for (byte segCount = 0; segCount < 7; ++segCount) {
    digitalWrite(pin, seven_seg_digits[digit][segCount]);
    ++pin;
  for (byte count = 10; count > 0; --count) {
   sevenSegWrite(count - 1);
  delay(4000);
hi this works for seven segmen display, buy what i need to do is, when a press number 1 in my keypad 4x4 y need the same number in my seven segment display , if i press 2 i need the number 2 in m in my seven segment display and i need to do the same thing from 0 to 9.
What i have to use is 4x4 keypad, decoder 7447, and seven segment display.
thank you for all your help.
I need to do is, when a press number 1 in my keypad 4x4 y need the same number in my seven segment display , if i press 2 i need the number 2 in m in my seven segment display and i need to do the same thing from 0 to 9.
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
  • Moderator
i want code for display numbers atseven segment display using 4x4 keypad, decoder 7447 help me
