Hello,
I'm trying to run a tutorial I found on the arduino site, here, using the due:
The compiler returns an error with the example code: 't_sample' was not declared in this scope
My frustration is that the variable declared directly above it seems to work just fine. What's the problem here? Is the compiler broken?
Here's the beginning of the program listed on the tutorial:
#include "Waveforms.h"
#define oneHzSample 1000000/maxSamplesNum // sample for the 1Hz signal expressed in microseconds
const int button0 = 2, button1 = 3;
volatile int wave0 = 0, wave1 = 0;
int i = 0;
int sample;
analogWriteResolution(12); // set the analog output resolution to 12 bit (4096 levels)
analogReadResolution(12); // set the analog input resolution to 12 bit
attachInterrupt(button0, wave0Select, RISING); // Interrupt attached to the button connected to pin 2
attachInterrupt(button1, wave1Select, RISING); // Interrupt attached to the button connected to pin 3
sample = 0;
// Read the the potentiometer and map the value between the maximum and the minimum sample available
// 1 Hz is the minimum freq for the complete wave
// 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
sample = constrain(t_sample, 0, oneHzSample);
analogWrite(DAC0, waveformsTable[wave0]); // write the selected waveform on DAC0
_ analogWrite(DAC1, waveformsTable[wave1]); // write the selected waveform on DAC1_
