Laser Instrument (advice is needed)
not analog ones, because I won't have enough of those
You can use a 4051 to multiplex more analogue inputs. Reading an analogue signal with a digital pin will take too long for you in this situation.
Look at this project for how to use a 4051:-
http://www.thebox.myzen.co.uk/Hardware/MIDI_Footsteps.html
Grumpy_Mike:
MIDI Footsteps
A multiplexer can only read a single signal at a time. It would be nice if I'm able to read multiple signals, so I can hit multiple "strings" (lasers) at a time. Is there any other way that will have quick response time, other than buying an Arduino Mega?
But you've only got one A/D anyway, so you haven't lost anything.
You missunderstand, you can't read more than one signal at a time on an arduino, even a mega. There is only one analogue to digital converter and a multiplexer inside the chip. For what you are doing you will not notice any extra delay from an external multiplexer.
AWOL:
what do you mean exactly?
Grumpy_Mike:
So, how does it work? Does the arduino quickly read the analog values one by one?
Yes if that is what your program tells it to do.
Grumpy_Mike:
Which means I should be able to let him read multiple inputs quickly after eachother, right? Do you know how long it takes the arduino to read a series of 8 analog inputs?
Asked too quickly, just found this:
It takes about 100 microseconds (0.0001 s) to read an analog input, so the maximum reading rate is about 10,000 times a second.
Between 800 and 900 microseconds, assuming they're well matched.
Figure on about 110 microseconds per conversion. (finger-in-the-air figure)
Is that fast enough for you, I think it will be. You can speed it up if you reduce the resolution but there is no need.
Grumpy_Mike:
Yes it probably will be. This means it would be possible to play multiple tones at once, right? Providing I have the right piece of code, I could put my finger through a laser, giving a signal to the arduino. If I then keep my finger there and interrupt another beam, that would also be detected (in +-100 microseconds).
Thanks for the suggestion Mike!
All I need is 4051 now. This seems okay?: http://pieterfloris.nl/shop/product.php?id_product=386
No, on average it will be 400 or so microseconds.
AWOL:
Oops, misread. Thats fast enough too.
So with that IC it should be very doable.
Something else: It has been mentioned that driving the lasers is going to be rather tough, because of current that won't be completely constant. Heres the thing:
I've been looking at these: http://www.dealextreme.com/p/20mw-532nm-green-laser-module-3v-11-9mm-26887 lasers, I already have the 50mw version, and as you can see on the pictures, it already has some sort of IC on it, and I was wondering if maybe that is to stabilize the current? And if not, what IC would I need to do such a thing?
You can't wire modules like that in series, you will need a stabilised supply.
They are very powerful, make sure you construct this with the lasers pointing down and don't have anything that could give a reflection.
This is a video of my LED harp made about 12 years ago.
Grumpy_Mike:
So, it would be better to do it parallel, with 3v and 2A? (8x250mA)
Yes. You need a good regulator or split them up into two or more groups with a regulator each. Also have plenty of decoupling capacitors between each laser module.
Grumpy_Mike:
Thanks! I'll have to re-do my drawing, although I'm not really familiar with using decoupling capacitors and regulators.
For the capacitors, would wiring a cap from before the laser, to the ground (for each laser) do the trick?
See my page:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
