system
July 9, 2013, 10:21am
1
Hello ,
Im new to such thing as electronics , im a photo booth builder
i got the coin acceptor " CH-923 " and i programed it to identify and accept one type of coin " no cash value " and send 1 pulse ..
though i have a major problem with the programing ..
how can i program the arduino to a accept the pulse from the coin acceptor and turn it into a mouse click ? , Just like that !
i'll be grateful , thanks for your help .
system
July 9, 2013, 10:56am
2
That depends on how you have connected the coin acceptor to the Arduino.
You need the Arduino Mouse board (also known as a Leonardo or Micro).
system
July 16, 2013, 2:01pm
3
hey , i ordered the Leonardo once you told me to , and it has just arrived ..
what is next ..
system
July 16, 2013, 2:17pm
4
what is next ..
You write some code.
And, before you ask, you test the code. Then, you debug the code.
Hey did you manage to write some code? Got stuck with this too..
I never used interrupts before and don't have much time to finish this now.. Any example code?
Thanks!
hy,
try the next code
This sketch assumes that coin 1, will return 1 pulse, coin 2 will return 2 pulses, and so on.
Coin values:
1 = 0.5
2 = 1
3 = 2
4 = 10
const byte coinValues[4] = {
5, 10,50, 100}; //Coin values goes into this array
#define pulseTimeout 200 //How many milliseconds there are from the last impulse to the coin is determined (default 275)
#define actionTimeout 60000 //How many milliseconds before stored credit is reset (default 60000)
unsigned long lastAction = 0; //When last action was made
unsigned long lastPulse = 0; //When last pulse was send
int pulseCount = 0; //How many pulses we got
int currentCredit; //The current credit
void showCredit()
int credit = currentCredit/10;
int left = currentCredit % (currentCredit/10);
Serial.print("Current credit: ");
Serial.print(credit, DEC);
Serial.print(".");
Serial.print(left, DEC);
Serial.println("0");
attachInterrupt(0, acceptorCount, RISING); //Digital interrupt pin 1
attachInterrupt(1, acceptorPulse, RISING); //Digital interrupt pin 2
Serial.println("Coin Acceptor ready");
pulseCount = 0;
pinMode(13, OUTPUT);
unsigned long tempAction;
unsigned long tempPulse;
tempAction = lastAction;
tempPulse = lastPulse;
if (millis() - lastPulse >= pulseTimeout && pulseCount > 0 || pulseCount >= 4)
if (tempAction != lastAction || tempPulse != lastPulse) return; //Check if interrupt has fired since loop started, wait for next cycle if it has
tone(12, 1800, 150);
currentCredit += coinValues[pulseCount-1];
showCredit();
pulseCount = 0;
if ((millis() - lastAction >= actionTimeout) && (lastAction != 0) && (currentCredit > 0) && (pulseCount == 0))
currentCredit = 0;
lastAction = 0;
Serial.println("\n*** TIMEOUT! Credit reset. ***");
showCredit();
void acceptorPulse()
lastAction = millis();
lastPulse = millis();
pulseCount++;
void acceptorCount()
digitalWrite(13, digitalRead(13));
all credit goes to Coin acceptor - YouTube
system
June 24, 2014, 4:32pm
7
Coin values:
1 = 0.5
2 = 1
3 = 2
4 = 10
const byte coinValues[4] = { 5, 10,50, 100};
Isn't there a mismatch between comment and code there?
