Topic: HM-10 no AT but serial fine (Read 207 times) previous topic - next topic
mortonc
I've been playing around with my new HM-10 connected to a nano. Using the following code I am able to communicate backwards and forwards between the arduino IDE serial monitor and the HM-10 (via an ios BLE serial monitor).
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 2); // RX, TX
  while (!Serial) {
  mySerial.begin(9600);
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
However if I try to send AT commands to the unit either by typing into the arduino serial monitor or the app I do not receive any response. I have tried with carriage return, line ending, both and none but no repsonse from any.
I have also tried it while the unit is connected to my phone and while it is disconnected.
Does anybody know what might be causing this issue?
Nick_Pyner
This confirms your wiring and procedures are kosher
Quote
You cannot do it from the app. You can only send AT commands when Bluetooth is not in communication mode. Do it from the serial monitor.
mortonc
I Nick thank you for your response. I have tried it while the bluetooth is not connected and sent AT commands through the arduino IDE serial monitor but received no reply.
Nick_Pyner
This might be just a matter of terminating the commands. I'm not familiar with HM-10
http://www.martyncurrey.com/hm-10-bluetooth-4ble-modules/
