Topic: MegaCore issue flashing sketch over serial must compile as a Uno for Mega2560 (Read 53 times) previous topic - next topic
KawasakiZx10r
Hello i have been working on ways to flash my Arduino remotely with no need for a pc it has to run just of a  second MCU in my case an ESP8266-12.
I have a sketch that can run on any MCU and flash a Uno via Serial0 with the HEX file stored on an SD card, it uses stk500v1 protocols to flash over Serial and as i said this works fine on any 328p chip but not a Mega, so i flashed over Optiboot to my mega so i can use stk500v1 protocols to flash it and that works, well kind of, in the Arduino IDE i have to choose MegaCore Mega 2560 and i can flash the sketch, standard mega 2560 does not work as expected while running Megacore.
But using a slave MCU and the BootDrive sketch i found written by Kevin i can only flash the Mega 2560 over Serial when i compile the code as a Uno, selecting Megacore 2560 or just the standard Mega 2560 and compiling then flashing those Hex files fails.
Now this would be fine it i just had a simple sketch like blink but i need to use Serial2 and 3 and all the pins that a Mega offers ect, and when i try to compile a sketch for a Mega as a Uno with things that the Uno does not have i gets erros like Serial2 was not defined of course...
So i swear i read somewhere about changing the boards config in the Arduino files and rename or create one just named Uno with the Mega configs and so on, But i cant find that info, lol you know whats its like when you find something and can never find it again.
Any help please :)
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
KawasakiZx10r
Never mind i have added the custom board now and its working, i just copied the Mega settings made a copy and renamed it and changed the bootloader link to optiboot
Albert Einstein
