Also ich habe den internen Pullup verwendet.
Und den Sketch habe ich von der DCF77 Library
Der Sketch:
- InternalClockSync.pde
- example code illustrating time synced from a DCF77 receiver
- Thijs Elenbaas, 2012
- This example code is in the public domain.
This example shows how to fetch a DCF77 time and synchronize
the internal clock. In order for this example to give clear output,
make sure that you disable logging from the DCF library. You can
do this by commenting out #define VERBOSE_DEBUG 1 in Utils.cpp.
#include "DCF77.h"
#include "Time.h"
#define DCF_PIN 13 // Connection pin to DCF 77 device
#define DCF_INTERRUPT 0 // Interrupt number associated with pin
time_t time;
DCF77 DCF = DCF77(DCF_PIN,DCF_INTERRUPT);
DCF.Start();
Serial.println("Waiting for DCF77 time ... ");
Serial.println("It will take at least 2 minutes until a first update can be processed.");
time_t DCFtime = DCF.getTime(); // Check if new DCF77 time is available
if (DCFtime!=0)
Serial.println("Time is updated");
setTime(DCFtime);
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
Serial.println();
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
Im Serial Monitor sieht man immer nur das Unix Anfangsdatum also 1 Jan 1970
