Topic: Arduino resets when on wall power supply (Read 408 times) previous topic - next topic
matinzk
When I connect my Arduino Mega 2560 to a wall power supply and touch the reset pin the Arduino resets.
If I connect the Arduino to a USB cable to the laptop and touch the reset pin it doesn't reset.
Does anyone know what the issue could be?
Thank you.
spycatcher2k
You touching the reset pin, don't do it, no more problem!
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
avr_fred
Connect a 100nf capacitor between the GND pin of the Arduino and earth ground and your mysterious reset will not happen.
Do you use this same touch test method on mains connected devices? Just curious...
matinzk
The problem is that I have had a relay connected to the Arduino and when the relay opens and closes the Arduino also resets. I've disconnected it and narrowed the issue down to the reset pin receiving some kind of interference. In other words Arduino resets still without the relay connected too.
avr_fred
Oh, so this is another one of those posts where it's going to be twenty questions until we know what you're actually doing?  Okay, I'll play.
What's the relay controlling and at what voltage?
DrAzzy
Post the schematic or diagram of all connections. How are the connections made? Are you using decent connections, or thin wires in low quality breadboard?
What kind of power supply is it? Could the power supply be crap?
Also, is it a bare relay or a module? If it's a bare relay, have you installed a flyback diode? Without that, it will put a load of noise onto the power rails. Even with it, relays can do that - it's an inductive load.
You need to supply details on the relay (link to product page is fine) and power supply.
It is not unusual for relays to cause reset problems, though; often people wind up powering them via a separate supply.
Don't make us play 20 questions, give us enough information to solve your problem. Don't just answer one of our questions, answer them all, plus any other info that might be useful.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
matinzk
#6
Jan 11, 2018, 11:50 am Last Edit: Jan 11, 2018, 11:59 am by matinzk
The power supply is a regulated PC like power supply with variable voltage control.
This is the Arduino board: https://www.aliexpress.com/item/Mega-2560-PROMINI-5V-ATmega2560-16AU-NO-pinheaders-Compatible-for-Arduino-Mega-2560/32804483834.html?spm=a2g0s.9042311.0.0.cSaYWX
This is the relay module:
http://www.ebay.co.uk/itm/12V-Relay-Board-Module-Active-Low-1-2-4-8-Channel/282576987893?hash=item41cae6a6f5:m:mIaW_nDTbFLe7h3khwycsGg
Relay is powered via the GND and VCC pin of the Arduino itself.
As mentioned, regardless of whether relay module is connected to the Arduino board or not if I touch the RST/RESET pin with a little screwdriver for instance the board resets itself.
I have made up exact same circuit with one of these boards (below) and reset issue never happens. Could it be that this larger board has some extra components?
https://www.aliexpress.com/store/product/Mega-2560-CH340G-ATmega2560-16AU-Compatible-for-Arduino-Mega-2560/1950989_32517341214.html?spm=2114.12010612.0.0.7927fc035nMEW7
Thank you.
avr_fred
Quote
That's as clear as mud. Post a link or a picture please.
Quote
That could be the source of your problem, please post a schematic (hand drawn is fine) or clear photos of the components and wiring so that we can see how things are connected.
Quote
Possibly but the mini board reset circuit appears fine - although the board routing is obviously different. Here's the schematic: MEGA-PROMINI-ATmega2560
We still need to know what you're controlling with the relay. AC? DC? Please show this in the schematic or explain.
matinzk
Thank you for your kind reply.
The power supply was purchased a few years ago, I don't have an image or link for it.
Also I'm away so can't do any schematics.
I control a DC device with the relay but this happens when if no device is connected to the relay.
In the meantime regardless of the relay why does the board reset itself when RESET button is touched with a screwdriver?
Thank you.
