Topic: Cannot bootload Atmega1284p, verification error, first mismatch at byte 0x0000  (Read 335 times) previous topic - next topic
archimedes
Continuously getting the following:
verification error, first mismatch at byte 0x0000 0xfc != 0xfe
and the like:
verification error, first mismatch at byte 0x0000 0xfe != 0xd6
mismatch at byte 0x0000 0x00 != 0xd6
verification error, first mismatch at byte 0x1fc00 0x00 != 0x01
when trying to bootload standalone Atmega 1284 P (PU) by using Arduino ISP and Mightycore arduino core.
Tried different arduinos, different chips, usb cables and so on, all in vain.
The strange thing is that the program does not even recognize the Atmega1284 signature from time to time, it reads different signatures than it expects. When it gets the correct signature, it returns the above errors. This is different than the error that is the subject of this topic, but I just mentioned it now thinking they might be related somehow.
Other settings :
Clock : 8 Mhz external
Compiler LTO disabled (default)
BOD : 1.8 and 2.7 (tried both)
Full Arduino IDE message :
Code: [Select]
          System wide configuration file is "C:\Users\lenox\Documents\Arduino\hardware\MightyCore-master\avr/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Error while burning bootloader.
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xfe"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfe:
avrdude: load data efuse data from input file 0xfe:
avrdude: input file 0xfe contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xd6"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd6:
avrdude: load data hfuse data from input file 0xd6:
avrdude: input file 0xd6 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: verification error, first mismatch at byte 0x0000
         0xac != 0xd6
avrdude: verification error; content mismatch
avrdude done.  Thank you.
DrAzzy
Uh, the output you posted does not contain the error message you describe.
Also, what version of the Arduino IDE?
Finally, when posting verbose output, often the most useful line is the one right before the part you posted, that shows the avrdude command that the IDE is invoking. Please include it.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
archimedes
Sorry, didn't realize that the message was truncated. Now I corrected, and the error message is visible.
I use Arduino IDE 1.8.5
archimedes
Problem solved. Have not noticed this in the Arduino ISP :
// Uncomment following line to use the old Uno style wiring
// (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due...
//#define USE_OLD_STYLE_WIRING
Naturally, I was using the so-called old-style as shown on the arduino site.
