I was lazy so I just hard coded 24.
Each row must be a multiple of four bytes so I think the correct expressions for rowSize and fileSize are
int rowSize = 4*((3*w +3)/4);
int fileSize = 54 + h*rowSize;
This depends on truncation of integer divide.
The number of padding bytes at the end of a row would be:
int nPad = rowSize - 3*w;
In your case rowSize is 12 bytes and fileSize is 78 = (54 + 2*12).
Padding at the end of a row is three bytes.
I have not really tested this very well, just ran this sketch:
int h = 2;
for (int w = 0; w < 10; w++) {
Serial.print(w);
Serial.write(' ');
Serial.print(rowSize);
Serial.write(' ');
Serial.print(nPad);
Serial.write(' ');
Serial.println(fileSize);
void loop() {}
and got this result:
0 0 0 54
1 4 1 62
2 8 2 70
3 12 3 78
4 12 0 78
5 16 1 86
6 20 2 94
7 24 3 102
8 24 0 102
9 28 1 110
