Topic: Code for Python GUI (tkinter) to control output pins on Arduino UNO (Read 2848 times) previous topic - next topic
woodcncwnc
Program is partial working. I am able to turn pin 13 on and off.  What I am trying to do is have "true" feed back when the pin changes state. I am trying to send pin 13 status ("1" or "0") to a tkinter lable widget in python (below the "Exit" buttton) If I run using serial monitor everthing works correctly. I get the text "Hello" and when I pus the on button I get a "1" (no quotes) and when I push the off button I get a "0" (no quotes). Pushing Exit quits the program. I believe this is a python problem, I will also post there. Thanks for you help in advance
Jim
Python 3.6
#! /usr/bin/env python
import serial
import time
from tkinter import *
ArduinoSerial = serial.Serial('com3', 9600, timeout=.1)
time.sleep(2)
status1 = 0
def led_on():
    global status1
    ArduinoSerial.write(b'1')
    status1 = (ArduinoSerial.readline() ) # .decode('utf-8').strip())
def led_off():
    global status1
    ArduinoSerial.write(b'0')
def led_Exit():
    global status1
    status1 = "Quit"
    quit()
root = Tk()
root.title("Arduino Push Buttons")
btn1 = Button(root, text="Led on", command=led_on)
btn2 = Button(root, text="Led off", command=led_off)
btn3 = Button(root, text="Exit", command=led_Exit)
msg1 = Label (root, textvariable = status1, relief=RAISED,width = 10)
btn1.pack()
btn2.pack()
btn3.pack()
msg1.pack()
root.mainloop()
Arduino 1.6.12
int data;
  Serial.begin(9600); //initialize serial COM at 9600 baudrate
  pinMode(13, OUTPUT); //make the LED pin (13) as output
  digitalWrite (13, LOW);
  Serial.println("Hello");
  if (Serial.available()> 0)
    data = Serial.read();
   if (data == '1')
    digitalWrite (13, HIGH);
    Serial.println(digitalRead(13));
    data = '2';
   else if (data == '0')
    data = '2';
Robin2
This Python - Arduino demo and this Python GUI demo may be of interest.
They may need a little modification for Python 3 as it was written with 2.7
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
woodcncwnc
After several weeks of reading web pages and books, I have the Python / Arduino serial interface working.  It was all easy until I tried to get actual (live) status of Arduino digital outputs.  It was finally solved using the ".set()"  function, which was suggested by "Don Rozenberg  the author of  PAGE - Python Automatic GUI Generator".  Thanks to all for the feedback I received. I have attached the working Python and Arduino scripts.
Python ver 37-32, tkinter. TkVersion 8.6
# Arduino_Driver.py
import serial
import time
ArduinoSerial = serial.Serial('COM4', 9600, timeout=.1) # open serial port
time.sleep(2)
def led_on():
   ArduinoSerial.write(b'1') # set Arduino output pin 13 high
   var1.set(ArduinoSerial.readline().decode('utf-8').strip())# get Arduino output pin 13 status
   if var1.get() == '1':
       var1.set('Pin 13 is ON')
def led_off():
   ArduinoSerial.write(b'0') # set Arduino output pin 13 low
   var1.set(ArduinoSerial.readline().decode('utf-8').strip()) # get Arduino output pin 13 status
   if var1.get() == '0':
       var1.set('Pin 13 is OFF')
def led_Exit():
   ArduinoSerial.write(b'0') # set Arduino output pin 13 low and quit
   ArduinoSerial.close() # close serial port
   quit()
root = Tk()
font1 = "-family {Courier New} -size 10 -weight bold -slant roman -underline 0 -overstrike 0"
font2 = "-family {Segoe UI} -size 12 -weight bold -slant roman -underline 0 -overstrike 0"
font3 = "-family {@Arial Unicode MS} -size 12 -weight bold -slant roman -underline 1 -overstrike 0"
font4 = "-family {Segoe UI} -size 10 -weight bold -slant roman -underline 0 -overstrike 0"
var1 = StringVar()
var1.set('OFF')
root.geometry("430x200+600+200")
root.title("                                         Arduino Output Control")
root.configure(background="#d9d9d9")
btn1 = Button(root, text='Press for Led ON', font = font1, bg = 'light green', highlightbackground= 'black',   \
       borderwidth = 3, activebackground = 'light gray', relief=RAISED, command=led_on) # activate Arduino pin 13
btn1.place(relx=0.34, rely=0.10, height=30, width=150)
btn2 = Button(root, text='Press for Led OFF', font = font1, bg = 'red2', fg = 'white', highlightbackground= 'black',   \
       borderwidth = 3, activebackground = 'light gray', relief=RAISED, command=led_off) # deactivate Arduino pin 13
btn2.place(relx=0.34, rely=0.30, height=30, width=150)
btn3 = Button(root, text='Press to Exit', font = font3, bg = 'maroon1', highlightbackground= 'black',   \
       borderwidth = 3, activebackground = 'gray', relief=RAISED,command=led_Exit) # close serial port and quit program
btn3.place(relx=0.34, rely=0.50, height=30, width=150)
lbl1 = Label (root, textvariable = var1, font = font2, bg = 'light blue', fg = 'black', highlightbackground= 'black',   \
       borderwidth = 3, relief=RAISED) # message label for status of arduino pin 13
lbl1.place(relx=0.34, rely=0.70, height=30, width=150)
root.mainloop()
Arduino ver 1.8.5, Arduino UNO
int data;
  if (data == '1')
   data = '2';
   data = '2';
