Last year I did some experiments with multiplexed LEDs in the sun, and found that 50% on time was the lowest I could go and still be able to see the LEDs satisfactorily .
This was for 2 scoreboards that face the sun ( one faces East, the other West, so there is no respite with the time of day ! )
There was quite a long thread about it where I posted the pictures of results
http://forum.arduino.cc//index.php?topic=135826.0
Now I have to make some more of the same boards, so they cannot be dimmer than the first ones that I used SAA1064 chips to drive 4 columns of 7 LEDs at 50%.
For a 7 ( or 8 ) x 5 matrix, it needs 5 chips for 4 digits, so my boards need 30 chips for the 24 digits.
The main problem is that they are I2C driven, with only 4 choices of address, so I had to break them into groups of 4, and use an analog switch to connect the SDA to the right group.
This doesnt work out well for making a pcb for a group of 4 digits say, as I would need a separate SDA line for the 5th chip.
Does anyone know of a similar chip that uses SPI ( or shiftout ) 3 wires? ( I can get the SAA1064 for about $1.50. )
I use TPIC6B595 for my numeric 7 seg displays, but that only drives 8 segments of 16 LEDs.
I have got quotes for LED panels from China that say they use 1/4 drive for outdoor displays, using 74xx595s but I am not sure how.
Perhaps I should just use one 74HC595 latched for each column, they are only 25c in bulk.
My pitch is 13mm I think, and the chips are 7mm wide so they would fit between the rows.
I could have 5 separate latch lines to each group of panels, so I wouldn't have to send the data through the whole 120 chips.
Speed is not a consideration as the scores change rarely, and the clock every second.
I could turn the 5v down to save power wastage in the series resistors ( the 595 works down to 2v but I would have to consider the atmega328 voltage)
To keep in spec I would have to limit the LED current to 10mA as the max supply pin current is 70mA, but the LEDs I am using now are a lot brighter than last year anyway, and they were running at 18mA / 50% duty cycle .
Does anyone know what is normally used for latched displays ?
