Topic: Water meter pulse connection (Read 391 times) previous topic - next topic
godfaaather
Hi
I have a water (consumption) meter (DIEHL Altair), with a pulse reader (Izar pulse) linked below; and I would like to connect these to Arduino (I have Uno). Here are the units I have with their specs:
http://www.diehl.com/fileadmin/diehl-metering/pdb/FR_EN_Web/familie157354/ALTAIR_V4.pdf
http://www.diehl.com/fileadmin/diehl-metering/pdb/HU_EN_Web/familie3126674/IZAR_PULSE_H.pdf
The pulse reader has three wires (white, brown, green) which seem to be for 'pulse, ground, tampering.
Any help is much appreciated; how I should connect these to the pins, and what code to use to read the pulses.
Thanks
Paul_KD7HB
#1
Nov 17, 2017, 07:57 pm Last Edit: Nov 17, 2017, 07:58 pm by Paul_KD7HB
Hi, and welcome to the Arduino forum!
The PDF states the sensor is an "open collector" transistor, which means you treat it just like a push button switch. Attach the pulse to any Arduino pin and write the code to use "internal pull up resistor" on that pin. Connect the ground wire to the Arduino ground.
Just count the "button switch presses" and you will be counting the turns of the sensor magnet.
Lots of sample code to count button presses are available.
Paul
hammy
I've found it worth while putting an external , say 10k , pull up resistor  - the internal one is high impedance and you make get false triggering without it ( a problem I have experienced)
