I've just recently started playing with a standard Arduino NG board (AtMega8) and am working to connect several switches to the board and tell which of the switches are active and which was the first switch activated. The program checks pins 5 and 7 to which the switches are connected and then uses the Serial.print function to print a(pin 5) or b(pin 7) out along with a 1(on) or 0(off) depending on the switch state. The problem is that after a short number of lines ~64 the program crashes or stops transmitting data back out on the serial. The TX light on the board stops flashes as it does for the earlier readings (before 64ish). I'm not sure if it is the way I've written the code or if I need to do something else but any suggestions, comments or advice would be welcome. I'm using a Mac OS X 10.4.8 and the Arduino 0007 IDE.
The code is
int switchAPin = 5;
int switchAState = LOW;
int switchBPin = 7;
int switchBState = LOW;
int switchPins[2];
char pinsToSwitches[2] = {'a', 'b'};
char switchOrder[2] = {'Z', 'Z'};
int activeListSwitches [2] = {0,0};
int val = 0; // variable to store the data from the serial port
int timeOut = 500;
int counter = 1;
int startTime = 0;
char processing = 'N';
pinMode(switchAPin, INPUT);
digitalWrite(switchAPin, HIGH);
pinMode(switchBPin, INPUT);
digitalWrite(switchBPin, HIGH);
Serial.begin(9600); // connect to the serial port
Serial.println("\nReady for data entry"); // print readyiness message to serial monitor for user
void loop () {
startTime = millis();
for (int i=0; i < 2; i++)
activeListSwitches[i] = 0;
switchOrder[i] = 'Z';
processing='N';
while (millis() - startTime < timeOut)
switchAState = digitalRead(switchAPin); // read the input pin for switchAPin
switchPins[0] = switchAState;
switchBState = digitalRead(switchBPin); // read the input pin for switchBPin
switchPins[1] = switchBState;
if (switchAState == LOW) // Switch A active
activeListSwitches[0] = 1;
processing='Y';
if ( switchOrder[0] == 'Z' )
switchOrder[0] = 'a';
else if ( switchOrder[1] == 'Z' && switchOrder[0] != 'a')
switchOrder[1] = 'a';
//ignore - already set
if (switchBState == LOW) // Switch B active
activeListSwitches[1] = 1;
processing='Y';
switchOrder[0] = 'b';
else if ( switchOrder[1] == 'Z' && switchOrder[0] != 'b')
switchOrder[1] = 'b';
if (processing=='Y')
if (switchOrder[i] != 'Z')
Serial.print(switchOrder[i]);
Serial.print(activeListSwitches[i]);
Serial.println("");
The typical output is
a10
a10
a10
a10
b01
b01
b01
b01
b01
a10
a10
a10
a10
a10
a10
a10
ab11
ab11
ab11
ab11
ab11
ab11
ab11
ab11
ba11
ba11
b01
b01
ba11
ab11
ab11
ab11
ab11
ab11
a10
a10
a10
a10
a10
a10
a10
a10
a10
a10
ab11
Thanks
